Author Topic: Best handling mods to do  (Read 13024 times)
Offline andygo
Re: Best handling mods to do
« Reply #30 on: April 19, 2012, 01:03:59 am »
My mapped ed30 feels a bit floaty at the back. Interestingly its an inch higher all round than my standard GTi. That cannot help, and it must be down to the 18" wheels.
I would think it needs springs all round, with the rears a tad lower in proportion to the fronts, eg 1.5 inches lower on the rear and 1 inch lower on the front. A bit lower at the back would help with weight transfer under braking, which is when the car feels floaty at the back. IMHO of course..
Offline chris s
« Reply #31 on: April 19, 2012, 09:03:25 am »
Glad i am not the only one to have the floating rear end on their ed30
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline gazon69
« Reply #32 on: April 19, 2012, 09:29:37 am »
Ok I have made up my mind and want to get one, which one is the most recommended 1 to go for? Also how is the fitting on them?
Autotech, very light, stiff and adjustable.
« Reply #33 on: April 19, 2012, 09:40:01 am »
No floaty rear on my Mk5 GTI - Not since KW V3 coilovers plus some rear camber adjustment by VWR. I believe that the stock Mk5 GTI rear suspension allows for a small amount of rear camber adjustment anyway. Also, S3 rear brakes (AP's on the front) make the car feel very well planted under any heavy braking.
And, if you don't already know, it's very important on our FWD cars to put your deepest tread tyres on the rear - So, new ones on the rear and move the previous rears to the front when the fronts have got down to 2mm.
« Reply #34 on: April 19, 2012, 10:05:32 am »
I gotta agree Robin. The S3/R32 brakes on the rear make a massive difference. It was when braking with the standard setup when I felt the rear wallow/float the most.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2023k5kvk7nt4cfh3am9mpmpi9&/topic,19740.0.html
« Reply #35 on: April 19, 2012, 10:23:00 am »
Small brakes on the back FTW  :driver:
Offline andygo
« Reply #36 on: April 19, 2012, 10:59:19 am »
Why is it very important to have the tyres with most tread on the back. I was told that by a Thick Fit Fitter once, but he didn't know why. Personally, I think that is a load of tosh.
« Reply #37 on: April 19, 2012, 01:30:42 pm »
....Discussed here: http://www.mk5golfgti.co.uk/forum/index.php/topic,46218.0.html  < Read Reply #2 by ianv5.
What/who is "a Thick Fit Fitter"? A dumb blonde babe tyre fitter who is very fit?  :confused:
justsean
« Reply #38 on: April 19, 2012, 03:19:11 pm »
I'm getting the porsche 996TT brake setup in the front next month, comments suggest I should be doing the rears too at least to S3/R32? I'm planning on sorting out the handling next as I agree with all the above, ed30 feels 'light' in the rear in the bends! I see atleast another 1k disappearing quicker than i had planned here   :pomppomp:
Offline andygo
« Reply #39 on: April 19, 2012, 04:44:18 pm »
Anything that makes the gti a bit oversteery is a bonus, not a hindrance. Its a real nuisance and pretty much impossible to do these days with all the nannying built into the car. You can't even left foot brake.
And the extra tread depth at the back only lasts for a while, so how on earth do people cope when they are at 5 or 6mm and the fronts at 3 or 4? If they can't cope, then maybe they should get something even easier to drive..
And talking a bit from experience, I have had golf gti mk1's, 2's and 5's. I used to tarmac special stage rally the 1 and 2's...
Having said that, I'll chuck it off next time it rains, lol.
Oh, Kwick Fit Fitter by the way.  :)
« Reply #40 on: April 19, 2012, 05:06:32 pm »
I have that setup & with the S3 rears heavy braking is very good & stable  :happy2:
Offline black-a4
« Reply #41 on: April 19, 2012, 06:15:26 pm »
I've just bought a WALK for my GTI, as well as Sportline lowering springs. When I'm in there I will probably replace the front control arm bushes as well. What is recommended..... SuperPro?
Offline Russ_leeds
« Reply #42 on: April 19, 2012, 07:36:02 pm »
i have the autotech arb's and they're brilliant, 3 way adjustable aswell :happy2:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #43 on: April 19, 2012, 10:17:28 pm »
dont do what i did and do it arse about tit.
i fitted walk.
then i fitted tt arms at same time as putting eibach arb's on front and rear setting the rear to stiff.
the handling was at best "twitchy" as i still had the oem dampers and springs and they could not react quick enough to the aggressive rear arb setting.
put bilstein b12 kit and 4 wheel alignment with some negative camber and the difference was... :pomppomp:
