Author Topic: KW V1  (Read 1898 times)
Offline martinj46
KW V1
« on: April 16, 2012, 10:55:26 am »
I've recently had a brand new set of KW V1 fitted to my GTI.  The garage left them set farily high, so I went to lower them at the weekend.  The fronts were no problem, the rears however I can't figure it out...  There's the top mount on the spring, with the threaded section mounted to the car, and the purple adjusting collar.  However when I try to turn the collar to lower/raise the height, both parts turn together.  It looks like the threaded section isn't actually secured to the car in anyway, is this right?  The only way I can think of adjusting it otherwise it to remove it from the car, which surely isn't the case?
I've probably missed something really obvious, but any help will be greatly appreciated.
Offline boxxer1973
Re: KW V1
« Reply #1 on: April 16, 2012, 11:05:08 am »
Need to take the springs out as the top is held in with the pressure of the spring.
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline martinj46
Re: KW V1
« Reply #2 on: April 16, 2012, 11:16:08 am »
That's the answer I wasn't hoping for.  Cheers for the fast reply though.
How do you get the springs out?  I tried to but couldn't get the hub etc to drop low enough, even with the shock absorber unbolted?
Offline boxxer1973
Re: KW V1
« Reply #3 on: April 16, 2012, 02:27:35 pm »
Haven't with mine yet but I'd imaging shock and remove arb bolt
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: KW V1
« Reply #4 on: April 16, 2012, 08:35:55 pm »
I never removed spring when adjusting my V3's on my R32.. though i did undo the rear shock top mount(2bolts) and pull the trailing arm to reduce the load on the spring to make it easier to adjust the platform...
Diesel Daily Hack.
Offline martinj46
Re: KW V1
« Reply #5 on: April 16, 2012, 09:50:02 pm »
Cheers for the replies.  I'll have another attempt at the weekend hopefully.
Offline higher1
Re: KW V1
« Reply #6 on: April 16, 2012, 10:16:23 pm »
Just remove the bolt that secures the bottom arm to the hub then the bottom arm/wishbone can be pulled down that's the part the bottom of the spring sits on only takes mins to do with the wheel off
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
