Author Topic: Let's talk Load Ratings...  (Read 1672 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: April 16, 2012, 03:22:04 pm »
Hi guys, I want to put semi slicks on over summer but wanted the R1R not the R888.
The R1R only has a load rating of 88 not 92.
Having discussed with h4rdy, insurer seems to be saying is not a problem as long as you inform them but how much significance should you put on a load rating ie on the road will it be dangerous/disadvantages of running a tyre with 88 over 92?  :rolleye:
Thanks in advance
Re: Let's talk Load Ratings...
« Reply #1 on: April 16, 2012, 03:29:48 pm »
An 88 load rating tyre can safely carry 560kg per tyre so unless you load your car with lead to surpass a gross weight of 2240kg (560x4) then you should have nothing to worry about.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: April 16, 2012, 03:35:54 pm »
Cheers Ayoub, just wanted to double check as, god forbid, dont want to make a claim and discover that the insurer loses the plot because have not fitted the correct load rating tyre to the vehicle as per out of the factory. I will call Greenlight before making purchase  :drinking:
« Last Edit: April 16, 2012, 04:03:14 pm by berg »
« Reply #3 on: April 16, 2012, 03:41:37 pm »
If the speed rating for the tyre is correct for your car then you should have no worries about using it.
Offline DanGB
  • Different
« Reply #4 on: April 16, 2012, 05:22:47 pm »
I really dont think it is as simple as that, the tyres are not loaded equally, ie; the fronts carry a fair bit more weight, and then the fronts dont carry and equal division of the weight.
« Last Edit: April 16, 2012, 05:28:00 pm by DanGB »
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
« Reply #5 on: April 16, 2012, 05:26:16 pm »
Sub'd  :popcornsoda:
Offline robern2
« Reply #6 on: April 17, 2012, 09:15:10 pm »
The Incorrect load rating is not recommended by michelin hence why they don't recommend225/40/18 88 y xl
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #7 on: April 17, 2012, 09:20:11 pm »
so basically are we saying anyone running R1R's or any semi slicks not with a 92 rating run a risk of tyre failure and wipe out? If so look like will be plumping for some R888's as they seem to be the only ones with a 92 rating  :confused: :scared:
Offline chungster
« Reply #8 on: April 17, 2012, 09:31:51 pm »
88 load rating should be ok. If you think about it your car weighs what ~1400kgs
Would the car really have over 1100kgs of that over the front axle / front half of the car??
I don't think the FtoR weight distribution is at 79/21 !!!!
But don't take my word for it though, just something I've looked into in the past!  :happy2:
« Reply #9 on: April 17, 2012, 09:59:34 pm »
manufactors of tyres say you can put a higher speed rating on but not a lower load rating for the car
http://www.ctyres.co.uk/tyre_info/tyre_load_index.html
« Reply #10 on: April 17, 2012, 10:01:09 pm »
Your bread& butter so will take your word for it, may have to order some more 888s for the back then  :innocent:
« Reply #11 on: April 17, 2012, 10:07:02 pm »
had a customer come in last week with a porsche 911 and wanted to put cheap crappytyres on as he couldn't afford some thing decent for it-- i told him to sell it then i i wasn't going to risk his safety  :laugh:
« Reply #12 on: April 17, 2012, 10:08:03 pm »
Would you sell me Nankangs for the money pit?  :laugh:
« Reply #13 on: April 17, 2012, 10:09:28 pm »
Remoulds :signLOL:
« Reply #14 on: April 17, 2012, 10:10:03 pm »
