Author Topic: Creaking from front suspension?  (Read 1098 times)
Offline George
« on: April 21, 2012, 10:57:26 am »
Hi all, I have a creaking from my front suspension when turning slowly on full lock. I'm suspecting these is either the subframe bolts being loose or the top mounts need replacing. Is the top mount made up of a rubber cone with a bearing inserted into the centre? If so I guess it's only worth replacing the bearing?
Thanks  :happy2:
