Author Topic: Carpet mats attention  (Read 986 times)
Offline suave
  • -Given: 31
« on: April 21, 2012, 03:18:21 pm »
Has anyone cleaned their GTI carpet mats with liquid?
I bought a carpet tool for rotary but wonder exactly how much liquid or rather APC I can use on them. I don't want the back of the mat getting sodden. Do you just spritz a bit of APC and work it or do you need to nearly dampen the mat?
Any expertise appreciated as my driver's mat is very grubby and needs revived.
Re: Carpet mats attention
« Reply #1 on: April 21, 2012, 07:43:23 pm »
Just give it a good spray all over concentrating on the heel area for the drivers mat. You'd have to be spraying for a while to get it to soak through.
Once you've finished scrubbing go over it with one of the crevis tools on the vac, this will help remove a lot of the moisture!  :happy2:
Offline suave
  • -Given: 31
« Reply #2 on: April 21, 2012, 09:29:10 pm »
 Cheers for your help and advice.
Do you use a rotary carpet tool or a wet vac on mats?
« Reply #3 on: April 21, 2012, 09:32:21 pm »
Depends how bad they are, but 99% of the time I use either APC or Valet Pro and a stiff brush, then the vac!  :happy2:
Offline suave
  • -Given: 31
« Reply #4 on: April 21, 2012, 09:42:13 pm »
Thanks - your work looks awesome too!
I like the idea of this CG carpet tool so fingers crossed.
