Author Topic: Blueflame Performance TBE  (Read 4947 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
« on: April 21, 2012, 06:12:41 pm »
WHY
Continuing on from my misfire problems culminating in installing NGKs, I continued to suffer with being down on power. R-Tech confirmed that my car was only making 120bhp, and making dangerous amounts of timing pull when flat out. There wasn't enough air coming in either, although there were no signs of a turbo failure.
Likely diagnosis - blocked cat
SOURCING
Was umming and erring over what to fit. Wanted to go BCS, but Blueflame recently had a cracking offer on TBEs for £750 fitted. With cost being a concern as I'm saving up to move to London in September I settled on Blueflame and everything was booked.
FITTING
Price above included fitting costs. As the exhaust is made on the car, and isn't an off the shelf product mine was slightly customised to what I wanted to achieve. It has a 3" downpipe with 100cell sports cat, and is 3" all the way to the centre silencer, after which it narrows down to reduce the amount of noise. In place of the rear suitcase there is another small silencer.
OTHER VERSIONS
Milltek
Pipewerx
BCS
Jetex
APR
etc. etc. etc.
PLUS POINTS
1. Cost - £750 fitted for a TBE with a sports cat is a fantastic price
2. My power is back!!!
3. Increase in fuel economy
4. Even without the rear suitcase the exhaust is very civilised when cruising, and not all that intrusive even when you're pressing on
5. No CEL
MINUS POINTS
The tips are cartoonishly big which takes away from the stealth look I was going for. It's a taste thing, and no doubt some will really like it:
SUMMARY
Simply fantastic system. Comes with a lifetime warranty on everything but the cat too, so no worries about failures. I'm really thrilled. Was grinning all the way home.
100% recommended.
« Last Edit: April 23, 2012, 09:49:21 am by sub39h »
PLANS: Stage 2+
Re: Blueflame Performance TBE
« Reply #1 on: April 21, 2012, 06:16:27 pm »
excellent offer--the tips of the exhaust look like the same as the milly rear ones at 80mm
Offline Adam_Blueflame
« Reply #2 on: April 23, 2012, 02:01:51 pm »
It's good to see that you're happy with the system Sub39h  :happy2:
Offline Paullie773
  • -Given: 18
« Reply #3 on: April 25, 2012, 05:12:27 pm »
Nice one! I've got the Blueflame TBE with 200 cell sports cat on my S3 and can't fault it and as you say, at that price with lifetime warranty you really can't go wrong  :happy2:
Offline Sammy
« Reply #4 on: April 25, 2012, 08:25:16 pm »
Nice exhaust same as mine  :happy2:
Have you got a build thread?
GTI MK5 with all the gooodies
K04 power going on soon!
« Reply #5 on: April 25, 2012, 09:46:15 pm »
I did a review on this system years ago just have a look in this section  :happy2:
Offline johnhol78
« Reply #6 on: April 29, 2012, 02:07:31 pm »
Have you had any problems with downpipe being too close to the heatshield and causing noise?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #7 on: May 08, 2012, 10:00:53 am »
No mate. My exhaust was built on the car and is nowhere near the heat shield
I'll get a photo for you tonight if it's not too rainy
PLANS: Stage 2+
Offline johnhol78
« Reply #8 on: May 08, 2012, 11:12:31 am »
That's fine, spoke to Blueflame and they redesigned the downpipe to be more central to the tunnel.  :happy2:
