Author Topic: S3 VS ED30  (Read 8163 times)
Re: S3 VS ED30
« Reply #30 on: April 22, 2012, 05:26:16 pm »
S3 = bigger injectors?
Don't think so but could be wrong
Re: S3 VS ED30
« Reply #31 on: April 22, 2012, 05:58:07 pm »
AFAIK S3, Cupra, ED30 Injectors the same
Re: S3 VS ED30
« Reply #32 on: April 22, 2012, 06:19:24 pm »
i can't see the vag group making any changes to a car in the range that has the engine fitted as it would be down to cost so its cheaper to leave the engines as is and just put them in any car model they want if you ask me
Offline Black9
  • -Given: 35
Re: S3 VS ED30
« Reply #33 on: April 22, 2012, 06:28:51 pm »
So unless I'm going high power I'm as well saving 150kg and some £££ and going for an edition 30. How much could I expect from a stage 1 car with air filter!?
Saintsteve
Re: S3 VS ED30
« Reply #34 on: April 22, 2012, 06:30:09 pm »
285 +/- 5
Offline Tamiyoman
  • -Receive: 39
Re: S3 VS ED30
« Reply #35 on: April 22, 2012, 06:53:01 pm »
285 +/- 5
I was Told By Jabbasport to expect around 310bhp with custom remap, TBE exhaust and intake system
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: S3 VS ED30
« Reply #36 on: April 22, 2012, 06:58:15 pm »
^^^ That would be Stage 2, he's asking about Stage 1 so no TBE  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: S3 VS ED30
« Reply #37 on: April 22, 2012, 07:22:41 pm »
I made 289bhp on JKM's rollers, stage 1 no hardware changes...
Diesel Daily Hack.
Offline Black9
  • -Given: 35
Re: S3 VS ED30
« Reply #38 on: April 22, 2012, 07:31:46 pm »
Now I just need to find an ED30, difficult to find well priced/low mileage examples with Xenons, SatNav and Highline. Would Like a DSG but a fail mechatronics unit makes me  :sick:
Saintsteve
Re: S3 VS ED30
« Reply #39 on: April 22, 2012, 07:34:03 pm »
Failed mech's are less likely now, as most in warranty failures would of been sorted. if you purchase from a dealers, then your warranty within purchase period would cover it.
A manual worn clutch failure is less likely to be covered on a 2nd hand car.
« Last Edit: April 22, 2012, 07:42:30 pm by Saintsteve »
Offline Tamiyoman
  • -Receive: 39
Re: S3 VS ED30
« Reply #40 on: April 22, 2012, 07:37:05 pm »
My 08 plate Candy ED30 mechantronics were replaced under warranty the week before I bought it and also came with a 3 year warranty on the box  :happy2:
Buying a DSG is not to be worried about if its been looked after.
Offline rosco07
Re: S3 VS ED30
« Reply #41 on: April 22, 2012, 10:25:44 pm »
More like 100kg as S3 kerb weight is 1450kg Ed30 appears to be around 1350kg depending on where you look - 1357kg was highest value I found during a quick search.
It's a tough choice however, Quattro in the wet is impressive.
I am led to believe the newer CDL code engines (found in the recent facelift cars) have a different intake cam compared to the previous S3 which had the same intake cam.
