Author Topic: LED Downlighters GU10 & MR16 best place to buy???  (Read 1783 times)
Offline Thor
  • -Receive: 25
« on: April 22, 2012, 09:23:54 pm »
Ok,  the house we've just bought has many downlighters in the kitchen, 8 No. GU10 50W and 8 No. MR16 35W bulbs.  I am thinking of changing these to LED's as from reading around it will save a fair bit of electricity.
Be grateful for commnets and experience people have had with LED lights and where you purchased them from/ approx costs etc.
Thanks  :happy2:
                                     Mk6 GTI
Offline v2brett
Re: LED Downlighters GU10 & MR16 best place to buy???
« Reply #1 on: April 22, 2012, 09:29:56 pm »
fitted some from b and q and at a quite a high price too,  they were garbage i put the old bulbs back in after a day.
they looked great with a nice crisp white light but gave off no useable light what so ever
Still Here!
Offline MitchGTI
« Reply #2 on: April 22, 2012, 09:38:22 pm »
hey matey! just replaced a couple of mine with the LED bulbs screw fix were fairly reasonable, other place to try is electrical center, more you buy the better price you will get also  :smiley:
MPS
« Reply #3 on: April 22, 2012, 09:43:06 pm »
That always used to be the trouble with LED's, the intensity, however you would think with the advancement of LED car lighting they would be able to apply the same technology to indoor lighting.
Offline Beddie
  • -Receive: 76
« Reply #4 on: April 22, 2012, 09:48:47 pm »
I use 9W LED GU10s that i get from work, will have a look who makes them in the morning as i have a box full in the back of my van  :happy2:
They have got better over the years and the 9W version we use gives off a good amount of light and due to them being 3 x 3W CREE Leds the beam angle is getting close to the performance of halogen GU10s imo..
Pretty pricey though as they are £16 each to us with discount and we buy thousands of the things!
Carbon Grey Edition 35 - Here
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #5 on: April 22, 2012, 09:53:45 pm »
Osram have just started selling some decent warm white LED gu10 an mr16 in b and a and are dimmable  aswell but cost over £25 each. Phillips have started doing the same aswell but can only get them through wholesalers.
The older style LED's are not all that good IMO and your better off sticking to the normal halogen ones until the price of the decent led ones drop.
Offline 182_blue
  • -Receive: 54
« Reply #6 on: April 23, 2012, 07:15:07 am »
I will watch this with interest, it was going to cost me over £200 in bulbs for my kitchen and utility so i didn't bother, £200 is a lot of electricity !!
Offline Thor
  • -Receive: 25
« Reply #7 on: April 23, 2012, 08:15:46 am »
Found this seller on ebaygum, might give them a try, 12 No. GU10 24smd led bulbs for £40.
http://www.ebay.co.uk/itm/12-X-GU10-MR16-21-38-48-60-3W-4W-LED-SMD-BULBS-DAY-WARM-WHITE-SPOT-LIGHTS-BULB-/270953193255?pt=UK_Light_Bulbs&var=&hash=item84bb15aaa8
Thanks for all the comments and thought too.  :happy2:
                                     Mk6 GTI
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #8 on: April 23, 2012, 12:33:53 pm »
I'm in a similar situation in that I moved into a new house last year which has 14 MR16 downlighters in the kitchen and 12 GU10's scattered between the bathrooms and utility room.  I bought 12 50w GU10 equivelent SMD's from ebay which were allegedly warm white / halogen type very similar to the ones above however the light they give off is a much cooler light and not quite as bright as halogens.  They are acceptable in 'utility' areas and of course much cheaper to run so I've kept them but don't expect a like for like halogen replacement.
I've sh*t canned my ideas to replace the downlights in the kitchen on the back of this.  You do have to spend big bucks to get true halogen equivelents.  Also bear in mind that you will have to replace the MR16 transformers to LED drivers or convert them to 240V bulbs as the transformers used for the halogen MR16's will most likely fry the LED's.  Some do and and some don't but you dont know until you try...
Sepang Blue S4 BE Avant
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #9 on: April 23, 2012, 02:28:30 pm »
I would avoid them eBay ones, had loads of them fail with a few LEDs on each lamp failing and they don't give out the right sort of light, they are more for decorative lighting more than anything and I would still be hesitant to use them for that.
Unfortunately to light the room properly with LEDs you need to spend then money.
As for transformers most are compatible with the halogen ones where as some require drivers. I believe most now have circuitry in the lamp to allow them to use normal halogen ones but always read the lamp spec before taking a chance
Offline RobH
  • Revo stg 2+
« Reply #10 on: April 23, 2012, 03:49:07 pm »
Ive fit some of these to shops and some in the house they are by far the best ive seen but come at a high price http://www.energysavingled.com/led-bulbs/59/7W-V6-LED-Spot-GU10-Twist-and-lock-fitting-
Beam angle and light output is eqivelent to a 50w halogen unlike 99% of leds that claim they are but arnt. They also use the latest cree chips and not the old smd stuff. If your not happy just send them back for a full refund simples.
Offline 182_blue
  • -Receive: 54
« Reply #11 on: April 23, 2012, 04:48:58 pm »
Nice, i can get the 10 i need for £323.91  :laugh: :surprised:
Offline RobH
  • Revo stg 2+
« Reply #12 on: April 23, 2012, 05:23:08 pm »
I just fit 67 in a shop :scared: he paid a bit less than £35.99 each though.
