September 24, 2024, 11:21:48 am
General
Detailing
Backing plate??
Topic: Backing plate?? (Read 909 times)
suave
Always Involved
-Given: 31
-Receive: 3
Backing plate??
April 24, 2012, 07:58:29 am »
If i'm using a 150mm pad on my rotary should i be using a smaller backing plate to allow the pad to be a bit bigger?
Or, do i just go for a 150mm backing plate too?
Anyone advise on the best backing plates out there?
Thanks for any advice.
luckyGti
Won't Shut up.
-Given: 44
-Receive: 27
Re: Backing plate??
Reply #1 on:
April 24, 2012, 08:49:59 am »
With 150mm pads people generally use 125mm backing plates. as far as which one really depends on whether you have a rotary or dual action as each one has a different fitment. Rotarys are M14 if I remember correctly.
Dodo 3m Flex and Festool all make great backing plates.
I'm sure the pros will advise shortly
General
Detailing
Backing plate??
