Author Topic: Glovebox removal - airbag warning  (Read 2706 times)
Offline edition_30
« on: April 24, 2012, 10:00:38 am »
I'm looking to swap my glovebox door as it has some damage. Now I have done a search regarding the removal but it seems I will need to disconnect the passenger airbag connection, however will this not throw up a fault code & stop it from working correctly? Some posts mention removing the battery but I dont want to loose my revo settings.
Offline Aweful_Truth
Re: Glovebox removal - airbag warning
« Reply #1 on: April 24, 2012, 11:29:59 am »
when i changed my seats over i just made sure i didn't turn the ignition on before they were swapped over so the car never realised that the airbags were disconnected and same when i changed my steering wheel over had no problems. but when i took the seats out a while ago i turned the ignition on without thinking and the airbag warning came on so i presume so long as you leave it off you should be fine! if it does come on i just took the car to a local VW specialist (non dealer) and they deleted the fault code for a fiver, dealer wanted £80  :surprised:
To Bad, So Sad, Bye Bye!
Offline skard
  • -Receive: 245
« Reply #2 on: April 24, 2012, 11:36:03 am »
I swapped out my glovebox last week. Pretty sure I turned the passenger airbag off by the switch, did the unplug/swap, then re-activated the switch before turning on the ignition and had no fault come up.
Offline edition_30
« Reply #3 on: April 24, 2012, 11:51:03 am »
Where is the switch located?
Offline skard
  • -Receive: 245
« Reply #4 on: April 24, 2012, 11:53:12 am »
It's the big one inside the glove box, top right
Offline edition_30
« Reply #5 on: April 24, 2012, 11:55:12 am »
Offline mb
  • -Receive: 29
« Reply #6 on: April 24, 2012, 06:38:47 pm »
I didn't disconnect the battery or switch the passenger airbag off when I changed my glovebox & didn't get any fault codes
Offline OEM+ DUB
« Reply #7 on: April 24, 2012, 09:14:53 pm »
+1 - No problems with mine either when I swapped mine!
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: April 24, 2012, 10:17:52 pm »
As long as you don't turn the ignition on when the plug is off then you won't log a fault.
Follow AKS tuning on Facebook
