Author Topic: The Official APR v3.1 Results Thread  (Read 11755 times)
Offline Keith@APR
  • -Receive: 36
    • Go APR
« on: April 24, 2012, 04:55:16 pm »
Hello Everyone,
There has been quite a bit of a stir going on as of late regarding APR's v3.1 ECU Recalibration for factory equipped Ko4 turbocharger engines.
APR has recently released v3.1 for all ED30/Pirelli Edition's, SLC R's, Golf R's, Scirocco R's, TT-S' and S3's developed, tested and approved for the UK market.
APR UK's Golf R was the primary development car so we will start with the results of it thus far.
2010 VW Golf R DSG Stage 2+
APR v3.1 ECU Recalibration
APR High Pressure Fuel Pump
VWR Induction System
VWR Turboback Exhaust
VWR Anti-roll Bars
VWR Lower Engine Mount
VWR Coilover Suspension
VWR Braking System
Haldex Performance Controller
Our first timed testing event was a few weeks ago at Santa Pod Raceway with yours truly behind the wheel:
Some of you may have seen Jonny's thread here http://www.vagoc.co.uk/vb/showthread.php?t=10722&showall=1 and as we had planned to run the Golf R at the MLR 30-130mph day we ended up at Bruntingthorpe instead.
With Jonny behind the wheel and some help with the launches from a wet surface we were able to achieve the following:
As we finish up our dyno installation project at our office in Milton Keynes, we will release Official Power Figures for v3.1 but here are some unofficial results in the meantime:
SEAT Leon Cupra R Stage 2+ APR v3.1 APR HPFP in Denmark:
Please feel free to update this thread with any other performance measurements you may have achieved with APR's v3.1.  Eventually I will build a database in this thread to document all of the various dyno graphs, 0-60 times, 1/4 mile times, etc.
Offline Janner_Sy
  • -Receive: 113
Re: The Official APR v3.1 Results Thread
« Reply #1 on: April 24, 2012, 05:36:50 pm »
You just need to post the timing slip in this thread http://www.mk5golfgti.co.uk/forum/index.php/topic,9244.msg512493.html#new then you'll be added to the 1/4 mile leaderboard
« Reply #2 on: April 24, 2012, 05:43:35 pm »
Leon Cupra APR St2+ V3.1
APR HPFP
APR Cooler
APR V3.1 St2+ map
ITG Maxogen (Heat reflective wrapped)
RS4 FPRV
NGK Irridium (Cant remember if 7's or 8's are currently in)
BCS 3" Decat TBE (Downpipe heat wrapped)
Neuspeed turbo discharge pipe
Air con pump & condensor removed
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #3 on: April 24, 2012, 06:08:11 pm »
Done!  Thank you.
Offline AndrewJB
  • die gelbe Baron
« Reply #4 on: December 22, 2012, 12:22:38 pm »
Just thought i would add my results to this
Leon Cupra R, APR St1+ V3.1
APR HPFP
Neuspeed P-FLO
THS FR3 Engine Mounts
Uprated Plugs (Cant remember the spec)
Dyno Graph (APR Motorsport UK's Maha Dyno in MK)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=36l9m3v897q4n8c0rr86c4pagr&/topic,19740.0.html
« Reply #5 on: December 22, 2012, 12:29:21 pm »
355bhp from stage 1?  :confused:
Offline AndrewJB
  • die gelbe Baron
« Reply #6 on: December 22, 2012, 03:39:23 pm »
its not Stage1 its Stage1 +    with HPFP and CAI
I cant have Stage2+ flashed because my downpipe hasnt been fitted yet
Two other runs after this ran 342 and 341, So i usually take an average of the 3 runs, i personally thing the 355 is quite high aswell i was hoping for 325-330 so was quite shocked when these figures came out.
The Stage1+ map is a vast improvement over Stage1 aswell, on the road its totally different, lots of Mid Range grunt now
« Last Edit: December 22, 2012, 03:42:00 pm by AndrewJB »
« Reply #7 on: December 22, 2012, 05:19:13 pm »
Sounds a lot to me. 350 is stage 2+ territory.
Offline AndrewJB
  • die gelbe Baron
« Reply #8 on: December 22, 2012, 05:24:40 pm »
a REVO LCR Stage1+ car made 340ish up in scotland a few weeks ago aswell
whatever it is truely making... it drives well  :innocent:
« Reply #9 on: December 23, 2012, 10:35:02 am »
A stage 1+ map should perform better than a stage 2 map. I guess in terms of performance it really it ought to be called stage 2+- or the current stage 2 should be the 1+ and the current 1+ should be the stage 2.  If you follow my fuzzy logic! :laugh:
Offline AndrewJB
  • die gelbe Baron
« Reply #10 on: December 23, 2012, 05:03:52 pm »
Stage1 -OEM Hardware
Stage2- Downpipe
Stage 2+ Downpipe + HPFP
Stage1+  HPFP
as you say its probably better than Stage2  :grin:
« Last Edit: December 23, 2012, 05:09:13 pm by AndrewJB »
