Author Topic: Brake help required  (Read 1793 times)
Offline vRS_Pagey
  • -Receive: 59
Brake help required
« on: April 24, 2012, 09:06:37 pm »
Tried fitting my rear brakes which were beautiful refurbished by DaveB a couple of months ago, but something seems to be wrong, when you depressed the pedal the piston moves out but it's nowhere near the pad!!  Can the pistons be wound out half an inch to met the piston safely???  When at rest piston is sitting almost flush with the back of the caliper.......
Offline Phil Miller
  • -Given: 86
Re: Brake help required
« Reply #1 on: April 24, 2012, 09:11:39 pm »
keep pumping the pedal and it will move out mate
Offline vRS_Pagey
  • -Receive: 59
« Reply #2 on: April 24, 2012, 09:15:52 pm »
It's not, when you lift the pedal it pulls back in????
Offline Phil Miller
  • -Given: 86
« Reply #3 on: April 24, 2012, 09:18:03 pm »
it will a little, but like i said it will move out, how fast are you pumping the pedal?
Offline vRS_Pagey
  • -Receive: 59
« Reply #4 on: April 24, 2012, 09:19:41 pm »
It's not me mate, my mechanic has the car......he has said that when you pump the pedal as soon as you take your foot off the piston is pulling back to the same position, no matter how many times he pushes it or how quick!?
« Last Edit: April 24, 2012, 09:24:16 pm by vRS_Pagey »
Offline Phil Miller
  • -Given: 86
« Reply #5 on: April 24, 2012, 09:26:34 pm »
Hmm ive never had that before, i take it he has managed to bleed the system? he could (in theroy) use a left hand threaded wind back tool to wind the piston out slightly, apart from that i dont know what else to suggest mate
Offline vRS_Pagey
  • -Receive: 59
« Reply #6 on: April 24, 2012, 09:29:29 pm »
The system is bled fine but not working, I think he will try winding the piston out a bit further and see if that helps, he's going back to his garage now, dedicated....!
Offline Phil Miller
  • -Given: 86
« Reply #7 on: April 24, 2012, 09:31:52 pm »
Hope he gets it sorted mate  :happy2:
Offline W8 Performance
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
« Reply #8 on: April 24, 2012, 09:54:05 pm »
Hope you get it sorted Lee. Doesn't sound like its a good day for brakes for us does it.
Offline PDT
  • -Receive: 142
« Reply #9 on: April 24, 2012, 09:59:15 pm »
handbrake on and off plenty of times will help  :wink:
« Reply #10 on: April 24, 2012, 10:09:59 pm »
Do hope you get it sorted Lee.  However, Muuuuhahahahahahaha  :P  Matching calipers aren't meant to be
Offline vRS_Pagey
  • -Receive: 59
« Reply #11 on: April 25, 2012, 08:12:31 am »
When I saw you had commented I just knew it wouldn't be anything constructive............s'pose I deserved it though, ar5e!  :signLOL:
Offline vRS_Pagey
  • -Receive: 59
« Reply #12 on: April 25, 2012, 08:13:58 am »
I've not anything yet today but honestly I'm baffled, I mean rear brake calipers are not exactly a technological master piece, are they?
Offline Thor
  • -Receive: 25
« Reply #13 on: April 25, 2012, 08:39:47 am »
This does sound strange, you'll have to let us know what the problem was once you've got it fixed.  Keepin my fingers crossed for you.  :happy2:
                                     Mk6 GTI
Offline vRS_Pagey
  • -Receive: 59
« Reply #14 on: April 25, 2012, 09:54:04 am »
Roger that, if the mechanic can't sort it, perhaps DaveB will have an answer, just waiting to hear back from him but I think he is currently on holiday.  :sad1:
