Hi,
Managed to collect a few highline parts for my gt 140 so was looking into the procedure for fitting them.
I have collected so far, MFSW, Highline clocks (973B) and Highline steering controller. All from 07 my car same as mine.
Am I correct in thinking I need a small airbag loom and does anyone have a part number to hand?
I do have access to VCDS so can code the controller and wheel but im confused as what to do with the cluster.
From what I have read I need the 7 digit SKC from my current cluster, Can I get this from using VCDS? If not how?
I assume I also need the same from the new (used) cluster. I understand this one is not possible to get using VCDS, what's the best way to do this?
I would then need to match the mileage, what do I need to do this?
I did have a read through a thread on here which went into it but I believe it is for the older clocks 971 type
Many thanks
![Smiley :smiley:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/smiley.gif)
