Author Topic: sps setings revo stage2+  (Read 2275 times)
Offline chopper
« on: April 26, 2012, 10:58:04 pm »
got revo stage 2+ on my edition 30 today... Karl at Revo suggested set boost 6, timing 4 and fuel 5 .... seems to drive well, but I notice other sps settings on search here seem a bit higher.
should i expect mine to be higher? im running APR HPFP and TBE  along with forge twintake and twintercooler.
Offline Poppa Dom
Re: sps setings revo stage2+
« Reply #1 on: April 26, 2012, 11:05:23 pm »
Every car is different, optimum settings can only be achieved via data logging really.
« Reply #2 on: April 26, 2012, 11:32:05 pm »
Who installed your map as the setting Karl Carl suggested seems to just be a safe starting point from where you can further tweak with logging.
Offline ktlstar
« Reply #3 on: April 27, 2012, 02:29:54 am »
mine is 8 5 5
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline heavyd
  • -Receive: 29
« Reply #4 on: April 27, 2012, 05:54:27 am »
I'm 8 5 6 ot 9 5 6
« Reply #5 on: April 27, 2012, 08:53:21 am »
.... x 2
I would primarily be guided for the actual B/T/F numbers by Revo or one of their dealers who you respect, not by us hyperinterwebbynet experts.
Also, my experience of Revo Karl is that he is always inclined to achieve the maximum performance for you.
Offline chopper
« Reply #6 on: April 28, 2012, 07:59:43 pm »
the settings i had applied were phoned over by Carl from Revo as the recommended setting for stage 2+. my installer loaded them on and data logged and felt everything was fine... he did suggest they could be increased though. i havent bought the sps unit yet and wondered would i expect to see much change in performance with an increase in the settings? how easy is the sps to use?
one final query if anyone has experience of it - i have a bluefin device which can do data logging. can i use it even if i have a revo remaP?
Offline Poppa Dom
« Reply #7 on: April 28, 2012, 08:28:12 pm »
Whereabouts are you based, maybe someone with an SPS and CCDs can get you all set up  :happy2:
Offline chopper
« Reply #8 on: April 28, 2012, 08:39:23 pm »
im based in northern ireland.... ill probably end up getting the sps and go back to my installer and get him to do the logs. ive been reading more about sps on revotechnik website and it seems fairly reasonable to understand. just need data logging done.
