Author Topic: Induction "flutter"  (Read 1619 times)
Offline Aweful_Truth
Induction "flutter"
« on: April 27, 2012, 01:46:40 pm »
Since I got the neuspeed induction kit it's whistled and then hissed when changing gear or letting off the throttle but that last two days it's stopped hissing and now makes a sort of fluttering noise. Is there a reason it's suddenly changed. Nothing has been changed in the engine bay for a long while either :/
To Bad, So Sad, Bye Bye!
  • -Receive: 291
Re: Induction "flutter"
« Reply #1 on: April 27, 2012, 01:50:16 pm »
Is the filter clean?
Offline Sammy
« Reply #2 on: April 27, 2012, 03:38:48 pm »
Diverter valve?
GTI MK5 with all the gooodies
K04 power going on soon!
Offline webby888
« Reply #3 on: April 27, 2012, 06:34:50 pm »
yeah mine flutters everynow and again too, pretty much always after iv been for an enthusiastic drive
« Reply #4 on: April 27, 2012, 07:03:57 pm »
cool thanks :) ill give the filter a clean as well
Offline MitchGTI
« Reply #5 on: April 27, 2012, 09:29:31 pm »
its a normal thing dont worry, my s3 and gti both did the same, i kinda liked it  :ashamed:
Offline john87
  • -Receive: 53
« Reply #6 on: April 28, 2012, 10:38:18 am »
if it flutters more often than not, and the car is on standard map, then you could have a stuck recirculation valve. My car does it with the TWINtake kit fitted, but only flutters if I release and re-apply the gas in quick succession...the rest of the time its just 'ptssshhhhhh'  :happy2:
Offline Sammy
« Reply #7 on: April 28, 2012, 12:26:17 pm »
Is your car manual or DSG?
spankydan
« Reply #8 on: April 28, 2012, 01:47:28 pm »
Depends what you have been doing if you have built up a lot of pressure by being on the throttle for a while it would tsssh rather than a flutter (technical engineering terms here :grin:).
