Author Topic: RNS-510 help...  (Read 7220 times)
Offline Mahooo3
  • -Given: 41
RNS-510 help...
« on: April 27, 2012, 07:39:24 pm »
Hi there,
Have been looking at the RNS-510 on ebay and I'm thinking about gettin a refurbished one.  My car is a 2008 edition 30 fitted with the RCD 500.  Here is a link to the one I am looking at:
http://www.ebay.co.uk/itm/190666425103?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Will I require a MFSW??  Does this seem like a good deal?
Matt
Offline Mahooo3
  • -Given: 41
Offline clivey
Re: RNS-510 help...
« Reply #2 on: April 27, 2012, 07:49:32 pm »
 hi mate ive fitted the rns 510 in my edition 30 works lovely. i just needed to buy a new aerial lead. clive :happy2:
Re: RNS-510 help...
« Reply #3 on: April 27, 2012, 07:54:20 pm »
Good price For the Led C version :happy2:
Comes with everything u need! You don't need the Steering wheel to operate the Rns510.
Do it. You won't regret it  :wink:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RNS-510 help...
« Reply #4 on: April 27, 2012, 07:57:32 pm »
for a little more you can have a Brand new H version
Cluster and Key coding
Location Great Yarmouth
vw55raz
Re: RNS-510 help...
« Reply #5 on: April 27, 2012, 08:32:25 pm »
^^^^ What Eddie said!
519 for a unit B is quite a lot. Get the LED version. Much better :D hopefully your canbus is a latest version so you shouldnt have battery drain issue.
Offline Mahooo3
  • -Given: 41
Re: RNS-510 help...
« Reply #6 on: April 28, 2012, 03:59:57 pm »
Excellent replies guys! :happy2: Thanks, helped a lot!  Couple more questions though lol...
Does this unit have six disc changer like my current RCD 500? and is there much difference between C and H?
Thanks again! :smiley:
Offline Squeeguk
Re: RNS-510 help...
« Reply #7 on: April 28, 2012, 04:05:23 pm »
It doesn't come with a 6 CD changer, but with the HDD built in, you can load around 25GB of music, so you don't ever need to use CD's again.
From my understanding, the H has a larger HDD, quicker processor and then the obvious benefits of more up to date firmware and probably maps too. And there is quite a difference in speed between the C & H thanks to the faster processor. It also seems that you can only go up to a certain firmware update on the older units due to the processor, whereas the newer firmware will work on the H.
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: RNS-510 help...
« Reply #8 on: April 28, 2012, 04:16:22 pm »
If you go for a Version C make sure its an LED one. As mentioned above theres not much difference between the C and H.
If you are going for a C version N13KKF over on R32oc can get them supply them with everything needed for £550 or I believe Eddie on here can get the new H versions if you want the newest one. :happy2:
Offline Mahooo3
  • -Given: 41
Re: RNS-510 help...
« Reply #9 on: April 28, 2012, 06:24:59 pm »
Again great help thanks!  How much could I pick up an 'H' version for then?
Offline Mahooo3
  • -Given: 41
Re: RNS-510 help...
« Reply #11 on: April 28, 2012, 07:12:16 pm »
Yeah another good one!
You should really get the latest version you can afford though  :happy2:
See Eddie for a H version  :wink:
Can't believe the prices :surprised:
When I think what I paid for my B version when that what first released, I could cry  :sad1:
.....still worth every penny I paid though. If you spend a fair bit of time in the car the RNS510 is one of the best mods you can buy!  :notworthy:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RNS-510 help...
« Reply #12 on: April 28, 2012, 07:15:00 pm »
get your post count up and I will PM you :happy2:
Offline Mahooo3
  • -Given: 41
Re: RNS-510 help...
« Reply #13 on: April 28, 2012, 07:20:05 pm »
Excellent guys thanks again!  How many posts do i need?
Saintsteve
Re: RNS-510 help...
« Reply #14 on: April 28, 2012, 07:26:55 pm »
10  :happy2:
