Author Topic: RVC and Not Switching Off  (Read 1593 times)
Offline Sparky Craig
  • Looking To Sell my R32 :(
    • My R32 Page
« on: April 28, 2012, 05:33:05 pm »
Hi All,
Battery went flat on the old beast a few week`s ago due to lack of use  :ashamed:
Charged it back up with a battery as per normal, but now the RNS510 has started to play up.  I wont turn off when I take the key out and also the RVC don`t come up on screen when I select reverse.
Just done a quick scan with VCD and It can`t see / connect with the NAV controller ??? AT ALL...
I can post a copy of the scan if required on here later but just thought someone might know off the top of their head, maybe a fuse or some other quick fix..
As a side note this has been working in the car 100% for at least 2 years and nothing has changed ...
Thanks in advance  :grin:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RVC and Not Switching Off
« Reply #1 on: April 28, 2012, 07:15:52 pm »
have you tried a reboot
Cluster and Key coding
Location Great Yarmouth
« Reply #2 on: April 28, 2012, 07:19:49 pm »
Stick the scan up Craig.
Failing that a gallon of V-Power and a box of Swan Vestas should cure your problems.  :wink:
    • My R32 Page
« Reply #3 on: April 28, 2012, 07:20:50 pm »
I`ve tried a button re-boot.
Here are some pictures from the system menu as well ???
I can`t understand it ?
Saintsteve
« Reply #4 on: April 28, 2012, 07:25:46 pm »
It's weird that in vcds in comes up no responce from controller.. But rns works from turning on/off.just won't shut down when the keys are removed.. is there a fuse between the can gateway to the nav?
« Last Edit: April 28, 2012, 07:29:56 pm by Saintsteve »
« Reply #5 on: April 28, 2012, 07:27:28 pm »
No Steve it's only a video link.
« Reply #6 on: April 28, 2012, 07:28:08 pm »
Has it worked since the extreme cold temps we had Craig?
    • My R32 Page
« Reply #7 on: April 28, 2012, 07:32:39 pm »
No idea Ian, you know it`s a only a weekend car and I`ve been working away alot in the past few months so not had time to enjoy it...
I got back last weekend and tried to start it and the battery was flat, I even had to put the radio code back in once I`d sorted the battery out...
Heres the fault codes listed on the scan ...
VCDS Version: Release 11.11.1
Data version: 20111209
Saturday,28,April,2012,18:01:00:26926
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76 77
VIN:             Mileage: 23160km/14390miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800106330015C
   Coding: FD0F07C8070001
   Shop #: WSC 01279 785 00200
   VCID: 2A7D317C85E4094
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 55
                    Mileage: 23161 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:08:16
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 55
                    Mileage: 23161 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:08:16
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
End   ---------------------------------------------------------------------
    • My R32 Page
« Reply #8 on: April 28, 2012, 07:36:42 pm »
just noticed when locking the car that the red LED (Drivers Door) flashes a few times then STAY`s on solid for a long time....
I`m sure this never happened before ??
 :ashamed:
Saintsteve
« Reply #9 on: April 28, 2012, 09:49:18 pm »
Is it worth disconnecting the battery now it's charged, and reconnecting Craig?  Some weird faults can be created, but as it looks like its drawn a blank with the in house guru's, worth a go. ? :happy2:
« Reply #10 on: April 28, 2012, 10:26:35 pm »
 :ashamed:
You might have acquired a central locking fault. On your scan there is a fault against the drivers door. These things do happen.
Ideally if you can remember the last time you used it and it was alright as the cold weather does strange things. My car changed itself to metric overnight and the bluetooth went titsup all down to the cold.  :confused:
    • My R32 Page
« Reply #11 on: May 07, 2012, 12:31:38 pm »
UPDATE:
All sorted now, just pulled the Main F19 fuse and left for 5 mins.
Weird fault   :stupid: but I`m happy again that it`s all working again 100%  :happy2:  :grin:
« Reply #12 on: May 07, 2012, 12:35:34 pm »
Nice to hear it's all sorted. :happy2:
Saintsteve
« Reply #13 on: May 07, 2012, 03:26:59 pm »
UPDATE:
Good to see by re- killing the battery supply cured it  :happy2:
