Author Topic: Cluster needle incorrect  (Read 1662 times)
vw55raz
« on: April 28, 2012, 10:25:41 pm »
Fitted my highline cluster today and noticed the needle on the revs is far below 0 when the car is off. Giving incorrect reading for when im driving.
Was thinking of opening the clusters and manually adjusting it but is there any other way to sort this?
Raz
Offline skard
  • -Receive: 245
Re: Cluster needle incorrect
« Reply #1 on: April 28, 2012, 10:28:39 pm »
Take the front cover off and rotate the needle anti-clockwise slowly - that's how I have done it in the past.
You can then go into Output Tests in 17-instruments to ensure it is right and do the needles so it sweeps the range (start - end - settles in middle).
vw55raz
« Reply #2 on: April 28, 2012, 10:46:44 pm »
Thanks Mate. I just had a play around with a spare set of clusters and did that, will do it with the highline ones tommoorww
Cheeers
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 28, 2012, 10:56:53 pm »
be careful when you adjust the needle always rotate anti clockwise, or you could ruin the actuator
Cluster and Key coding
Location Great Yarmouth
vw55raz
« Reply #4 on: April 28, 2012, 11:09:42 pm »
thanks eddie .  ill let you know how i get on tommorrow.
vw55raz
« Reply #5 on: April 30, 2012, 01:26:01 pm »
All sorted now  :jumpmove:
