Author Topic: Slight judder when still  (Read 2147 times)
Offline Gazza747
« on: April 30, 2012, 11:55:18 am »
I have had my car for a couple of months now and I have noticed when I am sitting in the car with the handbrake on there is a slight judder. Is this the engine mounts or an engine issue or is this normal?
(07gti)
« Last Edit: April 30, 2012, 12:46:19 pm by GAZZA747 »
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline DanGB
  • Different
Re: Slight judder when still
« Reply #1 on: April 30, 2012, 01:01:22 pm »
Misfiring perhaps?
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline GTIite
  • Build it.. don't buy it!!
« Reply #2 on: April 30, 2012, 01:05:43 pm »
Does it idle ok or does it go up and down the revs abit when stationary?
I have ETKA and ELSA - Happy to help if anyone needs anything. Instagram - @f11tvw
Rotiform VCE's : US Spec Rear Bumper : Colour Coded Side Skirts : US Grill : De-Wipered : Revo Stage 2+ Map : Revo Intake : Revo throttle pipe : THS Intercooler : K04 Conversion : Milltek Cat Back + Pipwerx Decat : Sachs Stage 3 Organic clutch + Single mass flywheel : Quaife ATB Differential : S3 Brakes + Vagbremtechnic discs : Full SuperPro Bushes : SuperPro ARB
Offline Gazza747
« Reply #3 on: April 30, 2012, 01:07:42 pm »
I had the air con fixed at vw recently and bought it from a vw dealer so I thought a misfire would have come up on their diagnostics. Everthing seems pretty good but I have run it on 95 ron  :sick: since I bought it. Maybe I should try 98+?
Offline Gazza747
« Reply #4 on: April 30, 2012, 01:08:28 pm »
The revs seem ok, just a slight murmer and I feel it though the seat.
Offline samdem
« Reply #5 on: April 30, 2012, 01:11:14 pm »
is it a DSG? could be that you have it in D with the handbrake on?
Offline Gazza747
« Reply #6 on: April 30, 2012, 01:15:20 pm »
sorry, it's a manual
Offline JJ
« Reply #7 on: April 30, 2012, 05:11:06 pm »
Sounds normal to me Gazza.  My '07 GTi is a manual and does exactly the same at idle.  Every now and again it has a bit of a wobble.  Think it's just one of the characteristics of the TFSI engine rather than a fault.  I run it on V Power or Tesco Momentum 99 - anything else and it runs like the proverbial bag of spanners!
« Last Edit: April 30, 2012, 05:15:38 pm by JJ »
Saintsteve
« Reply #8 on: April 30, 2012, 05:42:20 pm »
this  :happy2:
Offline holepunch
« Reply #9 on: April 30, 2012, 07:24:38 pm »
Mine only started doing this after a vw dealer changed the cambelt.  I'm sure I read somewhere that there is some margin of adjustment when carrying out the change but its often not carried out and results in the slightly rough idle.
Offline Gazza747
« Reply #10 on: April 30, 2012, 08:18:28 pm »
Thanks for the replies  :happy2:
When i bought the car the cam belt had just been done by vw, was only on 28k miles but was due as it is an 07 plate. Mind you they didn't change the water pump cheeky *****
I will try 98+ fuel for a few fill ups at least to see how things go
