Author Topic: AndrewJB's MK2 Leon Cupra R "die gelbe Baron" APR Stage 2+ (Quaife LSD time)  (Read 60961 times)
Offline chungster
Re: AndrewJB's MK2 Leon Cupra R "die gelbe Baron" APR Stage 1+
« Reply #120 on: December 12, 2012, 10:19:39 am »
Whp between the 2 is better comparison - negates the transmission loss calc then...
Offline Janner_Sy
  • -Receive: 113
« Reply #121 on: December 12, 2012, 10:21:44 am »
Thats not APR's dyno, that's Marlin Motors in MK  :wink:
Ah, so it is  :sad1: Ill call a taxi then  :grin:.  Thought mike had been on APRs as well and made the same for some reason.  FWIW, mine went on Marlins and made 251.2hp, and then on APRs i made .....251.9hp  :wink:
Offline AndrewJB
  • die gelbe Baron
« Reply #122 on: December 12, 2012, 10:27:28 am »
Sooo if thats correct then mine should make 355 on Marlins aswell, but the WHP should be around 270ish looking at mikes if not more
Might take a trip there next week before Alex bolts on my Stage2+ kit
Offline Janner_Sy
  • -Receive: 113
« Reply #123 on: December 12, 2012, 10:28:59 am »
Dyno Dynamics....thats where im heading with mine as soon as i have it.
Offline AndrewJB
  • die gelbe Baron
« Reply #124 on: December 12, 2012, 10:36:43 am »
Awesome GTI you get about 40lb.ft of torque extra  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #125 on: December 12, 2012, 10:38:36 am »
AMDTechnik is the best £/bhp you can do.  £70 dyno run gains you 50hp easily  :grin:
« Reply #126 on: December 12, 2012, 10:48:38 am »
So this is a stage 1 K04 car with OEM DP and cat with a Neuspeed intake making 355hp and 336lbft.
If that's the case then I must admit I am a little skeptical.  :confused:
Offline Janner_Sy
  • -Receive: 113
« Reply #127 on: December 12, 2012, 10:51:15 am »
Does ther Cupra R have the S3 spec intercooler?
« Reply #128 on: December 12, 2012, 10:52:35 am »
I don't think so.
Offline AndrewJB
  • die gelbe Baron
Re: Re: AndrewJB's MK2 Leon Cupra R "die gelbe Baron" APR Stage 1+
« Reply #129 on: December 12, 2012, 11:06:07 am »
Yes it does same CDLA engine as Golf R and S3. The "A" in the engine code indicates bigger intercooler
Sent from my GT-I9100 using Tapatalk 2
Offline Janner_Sy
  • -Receive: 113
« Reply #130 on: December 12, 2012, 11:07:52 am »
So you have everything needed for stage 2+ excluding the exhaust.
Offline AndrewJB
  • die gelbe Baron
« Reply #131 on: December 12, 2012, 11:18:53 am »
Downpipe and RS4 valve arent fitted yet hence why im running Stage1+ and not 2+
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #132 on: December 12, 2012, 10:33:31 pm »
Looking good, good results  :driver:
Offline AndrewJB
  • die gelbe Baron
« Reply #133 on: December 13, 2012, 11:56:29 am »
Cheers Jason :happy2:
Offline AndrewJB
  • die gelbe Baron
« Reply #134 on: January 09, 2013, 08:10:15 pm »
Been to see Alex @ AKS Tuning today for the rest of the Stage2+ hardware to be fitted
First thing was a H&R Rear-Anti Roll Bar (Front one is to be fitted at a later date)
Notice how bad the OEM exhaust looks after nearly 3 years
Next up was my Ebay special downpipe, 3" with 100cel sports cat, I took it to Alex and he has rewelded it and fitted a bigger and better flexi hose
Alex then fitted an AUDI RS4 Pressure Regulating Valve  which allows more pressure than the OEM valve
http://c1552172.r72.cf0.rackcdn.com/87830_x800.jpg
And finally Boost Gauge and Pillar Pod
Now my plan was to drive straight to APR tonight and get them to flash the Stage2+ tune, but my clutch is slipping really badly now so im now going to flash any more tune until ive got gearbox sorted out
Next up:
Southbend stage2 SMF & organic clutch
Quaife LSD
H&R Front ARB
AKS Tuning metal gearbox mounts
« Last Edit: January 09, 2013, 08:12:27 pm by AndrewJB »
