Author Topic: Help!  (Read 1465 times)
Offline da_ansa
Help!
« on: May 08, 2012, 12:55:36 pm »
My engine light came on yesterday  :surprised:
There are no other symptoms, the car seems to be running as it should no weird noises or jolts etc.. my mechanic is due to run a diagnostic later.
Just fearing the worst i havent had the golf very long
justsean
Re: Help!
« Reply #1 on: May 08, 2012, 03:25:55 pm »
hard to suggest anything if nothing feels wrong!
Offline ianv5
Re: Help!
« Reply #2 on: May 08, 2012, 03:32:23 pm »
Mine came on and car was running fine still. Turns out all it  was a broken clip that holds the connector into the MAF sensor . Worth a check  :happy2:
Offline nezquick
Re: Help!
« Reply #3 on: May 08, 2012, 03:34:05 pm »
wouldn't streess too much - if everything is running fine and its not in limp mode  :happy2: probably a o2 sensor in the decat or like mentioned the MAF.
Re: Help!
« Reply #4 on: May 08, 2012, 03:47:54 pm »
Any update on this?
Offline da_ansa
Re: Help!
« Reply #5 on: May 08, 2012, 06:51:47 pm »
Just come back from the diagnostic. the results are boost pressure regulation and intake manifold flap. I have the codes
what's the best way to repair these issues? since the faults have been cleared they light hasn't appeared
Offline nezquick
Re: Help!
« Reply #6 on: May 08, 2012, 07:03:43 pm »
Boost pressure is usually the diverter valve. run a sear on that mate and itll return loads
noot sure about the flap.. could be from where its dirty you could give it a clean
Offline da_ansa
Re: Help!
« Reply #7 on: May 08, 2012, 07:18:13 pm »
cheers and sorry to sound like such a noob but what is a sear? and what symptoms should I of noticed on my car with these faults? still seems fine to me :s
Offline nezquick
Re: Help!
« Reply #8 on: May 08, 2012, 10:33:10 pm »
Meant to say search sorry dude, check my build thread theres a link to some fault finding symptoms and fixes for the pcv valve and diverter valve  :happy2:
Offline v2brett
Re: Help!
« Reply #9 on: May 08, 2012, 10:41:26 pm »
as above check the diverter valve and if the the manifold intake problem returns try running a Adaptation with VCDS  :happy2:
did both faults show as being recent when diagnosed?
Still Here!
