Author Topic: Car shuddering at idle.  (Read 2388 times)
Offline uz
« on: May 08, 2012, 05:25:08 pm »
Hi guys,
I've done a search and can't find anything which seems to be the same as my problem with the car.
When I drive my car (Edition 30), it has an extremely lumpy idle; when it is stationary, the whole car judders noticeably (sometimes quite a lot). I've been trying to figure out what it is; I visited John Austin (Colchester) to have them look at it and the diagnostics showed a 'Cylinder 1 misfire' so they replaced the coil packs for me.
After the cylinder 1 coil was sorted, I sat in the car for a minute and there was no problem; it had stopped shaking. However, after just under 10 miles of driving, it has come back.
Has anybody else had similar problems in theirs?
Cheers,
Uz.
Steel Grey GTI Ed.30 - 18" Team Dynamics Pro Race 1.2 - Eibach SportLine Springs - RNS510 - Bluetooth Adapter Package - Winter Pack - Open Grilles
SOLD: Candy White GTI - 18" Monza 2's - RNS510 - Premium Bluetooth - Winter Pack - Xenons
Offline Ashley g
    • Durward's Autoshop
Re: Car shuddering at idle.
« Reply #1 on: May 16, 2012, 01:53:55 pm »
Could be another coilpack gone down, I've seen one fail after another a few times. Check with VW if your car is on the list for coilpack replacements for free!
2007 Edition 30, build number 30 - APR Stealth TBE - APR HPFP- APR stage 2 remap - Custom CAI - KW Clubsports - 10mm spacers on rear - VW Motorsport LSD, clutch & quick shift - A few poly bushes here and there!
*SOLD AND I MISS IT!! ANYONE SELLING A NICE ED30 PM ME* - UPDATE - I HAVE IT BACK!!!
Offline George
« Reply #2 on: May 16, 2012, 08:31:43 pm »
A tuner I know mentioned he's noticed this with several ED30s. He did suggest that I checked my coilpacks were the latest version (recalled), spark plugs were changed recently and a faultless scan. If you've done those three, I wouldn't worry about it!  :happy2:
Offline uz
« Reply #3 on: June 06, 2012, 06:48:58 pm »
Thanks guys, sorry for the slow reply (have had exams).  :scared:
My brother took it into a VW dealer after two specialists failed to diagnose and they told me it was a problem with the injectors and spark plugs, but then gave him a quote of £2000.  :sick:
I'm not sure what that was, but I was hoping it was only small, and it definitely doesn't look like it. I'll keep you posted if/when I find out.
Offline Harry171
« Reply #4 on: June 06, 2012, 09:59:15 pm »
Sounds a bit mad, seen similar with blocked breather valves/hoses.
Offline JMP
« Reply #5 on: June 07, 2012, 12:32:54 pm »
Is your PCV ok? this might affect idle.
Offline nezquick
« Reply #6 on: June 07, 2012, 12:39:02 pm »
Either that or check your dipstick and oil cap to ensure they are completely sealed - if everything is working correctly and you open or pull out either of these that will cause a rough lumpy ideal but can also do some damage if left for a long period of time.
