Author Topic: LED numberplate lamps - fuses?  (Read 1133 times)
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« on: May 09, 2012, 07:01:02 pm »
I successfully fitted an after-market set of integrated LED number plate lamps but realised they were too bright. I tried fitting a regular LED bulb and now neither unit is working.
Anyone know if there's a dedicated fuse for the numberplate lamps? I've tried turning the bulb around 180 degrees, it worked for a moment but now 'nothing'!
Weird. Was all working fine (but too bright) until I decided to monkey with it!
 57 plate Edition 30 BTW.
Thanks.
PR
Offline galaxie500
  • -Given: 38
UPDATE...Re: LED numberplate lamps - fuses?
« Reply #1 on: May 09, 2012, 10:59:00 pm »
Doh!
I hadn't checked the dash warning system - the number plate lights are too low voltage so up popped warning!
Has anyone tried these yet:
http://i1207.photobucket.com/albums/bb464/galaxie5004/Picture2.png
The Chinese units I first tried are far too bright. I assume the OEM units are good.
Gents?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: May 10, 2012, 10:29:47 pm »
Have a read here  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,30092.0.html
I have had the odd dash light warning, have the cold diagnosis turned off and all ok
