Author Topic: Eibach pro springs  (Read 1503 times)
Offline golfman
  • -Given: 17
Eibach pro springs
« on: May 17, 2009, 03:52:37 pm »
Can eibach pro springs be fitted to the standard suspension and if so what are the benefits?
will these springs lower the suspension?
cheers golfman :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline bennylenny88
  • needs moar lowwww
Re: Eibach pro springs
« Reply #1 on: May 17, 2009, 04:04:14 pm »
i heard aftermarket springs will proper kill your shocks..
« Reply #2 on: May 17, 2009, 04:22:49 pm »
Yes you can safely use those springs with your stock shocks though the life of your shocks may be reduced.
On a GTi those springs will drop your suspension by around 20-25mm.
As for benefits, the car should corner better and you'll get reduced nose dive when braking hard. The ride should be a little harder than stock.
Offline Rich
    • Carpet Underlay
« Reply #3 on: May 17, 2009, 04:34:30 pm »
I have them fitted on my car at the moment =)
Eibach make good springs - i had them on my other golf.
Will be buying Coilovers later on  :smiley:
Offline gillm
« Reply #4 on: May 17, 2009, 05:31:54 pm »
have have used them for over 2 years and had no problems with them the ride is slightly harder but im in 235/35/19 anyway so it will be worse then std
west tuned gt28 @ 340hp
