Author Topic: Problem with the headlight bulb, xenon corning etc... Help  (Read 1039 times)
Offline ConeKiller
HI guys
My Gf has a 2006 VW Eos, it has the xenon headlights that turn with the steering wheel, as well as the 'curb lighting lights' built in.
The passenger side dipped and main beam has stopped working, which has also caused a flashing yellow 'bulb' light on the dash.
How can this be sorted out without being taken to VW as its not just a simple bulb im guessing, anyone had this problem before and solved it themselves?
Thanks in advance  :happy2:
Offline mortygttdi
  • -Receive: 146
Re: Problem with the headlight bulb, xenon corning etc... Help
« Reply #1 on: May 10, 2012, 05:31:31 pm »
Im presuming the dipped and main beam are the same bulb so if one goes the other goes awsell??? if so then have a search of eBay for Eos xenons bulb and see if you can get one second hand or even new...VW still charge near on £100 for 1 bulb :scared:
The bulbs are quite simple to change but usually access is limited so makes a simple job turns into a nightmare
Darren
Offline ConeKiller
« Reply #2 on: May 12, 2012, 03:54:28 pm »
cheers for that, went in to vw as they have a few different bulbs and they dont even know!! got to take the bumper off to get at the bulb!! VW design!!
they want £145 for the bulb! think ebay will be the way forward!
