Author Topic: after market steering wheel ?  (Read 1844 times)
Offline gillm
« on: May 17, 2009, 05:24:29 pm »
anyone fitted one ? if so how do you remove the airbag ?
west tuned gt28 @ 340hp
Offline BeezerDiesel
  • -Given: 33
Re: after market steering wheel ?
« Reply #1 on: May 17, 2009, 05:41:44 pm »
The airbag is easy to remove. Ideally disconnect battery, then look behind the steering wheel with a mirror. You will see two U shaped metal hooks, one either side of the hub. Slide these off the lugs and the airbag will spring out of place. There is a big plug that connects it to the centre of the wheel.
It goes without saying though, make sure there is absolutely no static in the car as you don't want a broken nose!!!
Don't forget you'll then have an airbag warning light on your dash, unless this can be cancelled by removing the fuse(?).
Why do you want to replace the 'wheel though? I think it is the best part of the car.
Andy
7R
Offline gillm
« Reply #2 on: May 17, 2009, 05:47:49 pm »
just fancied a change . thanks for the info tho mate
Offline big al
« Reply #3 on: May 22, 2009, 03:25:21 pm »
I need to fit a new steering wheel, the car I have has obviously been driven by someone who likes sharp jewellery, but don't have the confidence to change it myself, heard that garages do it really cheap.
Offline andeep
« Reply #4 on: May 29, 2009, 05:59:19 pm »
Removing the fuse will still trigger an airbag fault. You need to use vagcom to reprogram it  :smiley:
2006 MK5 GTI -- Revo Stage 1 -- Neuspeed P-Flo -- OEM 'D' DV -- BSH Stage 2 PCV -- Forge Quickshifter -- BSH Pendulum Mount -- NS Boost Gauge + Pod
Offline Dario
  • booosting... :)
« Reply #5 on: June 15, 2009, 02:06:12 am »
you wont if you disconect the battery :)
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline katta
  • -Given: 19
« Reply #6 on: December 07, 2011, 05:24:52 pm »
Are you sure have you tried? I need to change mine, how many nuts are they to take off my wheel?
Offline RENNTAG
  • Premium Performance Parts
« Reply #7 on: December 07, 2011, 06:13:32 pm »
^^^ 1 nut. Just have to get the airbag off first
