Author Topic: where to spend my cash next?  (Read 2772 times)
Re: where to spend my cash next?
« Reply #15 on: May 10, 2012, 10:06:28 pm »
What suspension you lot recommend?
What's your budget first ?
Offline dan930
  • -Receive: 56
« Reply #16 on: May 10, 2012, 10:11:14 pm »
say around 5-700 quid,maybe a bit more... Only for road use as I don't do trackdays
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #17 on: May 10, 2012, 10:18:57 pm »
many suspension manufacturers, top of the range being the like bilstein, eibach, ohlins, sachs etc. It all depends how you use your car. If you plan to change a set up for example for a track day you can go for fully adjustable suspension. Some peeps have b16 bilstein which is top of the range You can also adjust height of your car.
If you are just looking for fit and forget suspension great for fast driving and occasional track day bilstein has b12 set I use and I can highly recommend. You can go for various car lowering options from 2.5 cm to 4 cm but you can't adjust.
I think there is a group buy as well at the moment
Paul
Offline dan930
  • -Receive: 56
« Reply #18 on: May 10, 2012, 10:29:48 pm »
Paul
Cheers mate,will check it out
MK6 golfR dsg
AKS TUNED
R TECH custom map
  • -Receive: 427
« Reply #19 on: May 10, 2012, 10:36:49 pm »
Would say rear adjustable ARB (Eibach/H&R) and lower engine mount (VRW/THS). Should be £500ish, really compliment your set up so far.
Offline George
« Reply #20 on: May 10, 2012, 10:41:27 pm »
Coilovers :happy2:
« Reply #21 on: May 10, 2012, 10:44:22 pm »
Definitely suspension and lower engine mount and diff and... and... and...  :evilgrin:
Offline Vick N
« Reply #22 on: May 11, 2012, 10:26:50 am »
HnR coilovers. Rear ARB, larger rear brakes and decent discs and pads.
A diff is a excellent upgrade, quaiffe or wavetrac.
Also good tyres!
