Author Topic: My outside tap.... thoughts?  (Read 4334 times)
« on: May 17, 2009, 06:14:09 pm »
Giving up on it now so thought i would put a post up here for ideas as autoperfection will be landing on my doorstep to detail 2 cars soon, so need to solve this
my house was built in the 70's and 2 years ago i moved in. the tap had an orange adaptor on it to allow me to click a hoselock hose end onto it and therefore meant i could wash the cars and buy a pressure washer.
well, the adaptor snapped.
the tap is a brass thing, not old, with a threaded end. i've been scouring for a new adaptor everywhere and nothing fits! i've bought almost everything from B&Q and Wyevale garden center and no joy, none of the adaptors, step ups or step downs etc will go on.
the closest i found was a 19mm one and that seems to be almost right but is just a fraction too small, almost as if it could do with being 19.5 or 20mm (a 21 is too big)
i know this is an odd question, but officially stumped now. currently suffering with a push-on-and-clamp-rubber-adaptor-piece-of-rubbish that sprays half the water up the wall and not down the hose
by some freak of nature has this happened to anyone else? am i just being dumb or do i need to get a plumber in to put me a new tap on?
:chicken:
Re: My outside tap.... thoughts?
« Reply #1 on: May 17, 2009, 06:26:40 pm »
the offending beastie:
(and yes i know the brickwork needs repointing  :smiley: perils of living on the coast)
Offline autoperfection.com
  • autoperfection.com
    • autoperfection shop
« Reply #2 on: May 17, 2009, 06:43:09 pm »
We've got a local company to us called Building and Plumbing supplies who do all that sort of stuff - we could pop in and see what they've got... if there's anything that looks like it might be right we could always pop it in the post for you to try?
« Reply #3 on: May 17, 2009, 06:57:05 pm »
this is the trouble with living in an area without decent shops like that  :ashamed: the views nice tho
i'm wondering wether its a metric/imperial issue?
i am worried you wont be able to use your gear
« Reply #4 on: May 17, 2009, 07:16:13 pm »
Well we can pop into BPS and see what we can find - if there's something that fits then hey-presto, problem solved... if not though, we'll work something out for when we're down there  :happy2:
« Reply #5 on: May 17, 2009, 07:22:17 pm »
duct tape?  :grin:
  • -Receive: 291
« Reply #6 on: May 17, 2009, 07:26:13 pm »
19mm = 0.748 in
19.5mm = 0.767 in
You have a 3/4 inch tap.
« Reply #7 on: May 17, 2009, 07:28:10 pm »
cheers dude, so adaptor wise what sort of size to i need to find? 3/4 inch? everything seems to get sold in mm's
  • -Receive: 291
« Reply #8 on: May 17, 2009, 07:29:58 pm »
Something like this? clicky
  • -Receive: 291
« Reply #9 on: May 17, 2009, 07:30:48 pm »
Are you able to measure the width of the spout with a ruler or something?
I wonder whether the tap's changed dimensions being out in the kinda environment you're describing?
Anyway, I guess you already bout this? clicky
(Edited the clicky)
« Last Edit: May 17, 2009, 07:34:44 pm by stealthwolf »
« Reply #10 on: May 17, 2009, 07:33:42 pm »
ooOOoo
to quote 08micsta.... "fabulous!"  :grin:
out of stock tho, at least i know what i'm looking for now :happy2:
EDIT: off to measure the tap  :chicken:
  • -Receive: 291
« Reply #11 on: May 17, 2009, 07:35:40 pm »
^^^Updated the link as the b&q one had the thread on the outside, not the inside which is required.
« Reply #12 on: May 17, 2009, 07:41:52 pm »
Offline pitch3110
« Reply #13 on: May 17, 2009, 08:05:36 pm »
I would take the tap off the base plate (leaving that in place & replace the tap (body)
does that make sense :confused: :confused:
HIS (collected 12.10.09) - B8 A4 2.0TDI-143PS Multi Exec S-Line Saloon...Lovin' Lava, 19's, MMI & lots more
TOY - 2001 Westfield 2.1 SEW,172bhp gocart.
HERS - Edition 30 Golf GTI no:0602, 3dr, Steel Grey, Xenons, Comfort Pack & lots more...
« Reply #14 on: May 17, 2009, 08:08:02 pm »
i does year, but if its an usual thread at one end it would suggest it would be at the base plate to meaning a new tap wouldnt go on, meaning a plumbing route. the previous adaptor was just a cheap bit of plastic, one of those would be a much more economical route
thanks for the idea though, it may well be the route i have to take
