Author Topic: K04 internal conversion/upgrade  (Read 3766 times)
Offline Jussa
  • Bicester
« on: May 11, 2012, 04:14:31 am »
Rather than replacing the existing turbo, What options are there in converting the K04 to a hybrid, or upgrading its internal compressor?
A mate of mine has a Focus RS - he was running 385bhp and sent his turbo away for a compressor replacement (apparently a Porsche 997 compressor was installed) and he is now running around 430bhp  :confused:
Now I don't know anything about the internals of turbo's, but I'm sure somebody here has some sort of experience on this?
 :popcornsoda:
Offline Sammy
Re: K04 internal conversion/upgrade
« Reply #1 on: May 11, 2012, 08:13:30 pm »
Thats interesting, Might consider doing this before upgrading
GTI MK5 with all the gooodies
K04 power going on soon!
Offline dan930
  • -Receive: 56
« Reply #2 on: May 11, 2012, 08:27:52 pm »
I think it the hybrid k04,might be wrong though..
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Jussa
  • Bicester
« Reply #3 on: May 11, 2012, 09:52:45 pm »
It is interesting, but it seems nobody here knows about it  :confused:
Offline damoegan
« Reply #4 on: May 11, 2012, 10:03:43 pm »
Has any of yous searched for "k04 hybrids" on here?
Lots of info..
Offline Russ_leeds
« Reply #5 on: May 11, 2012, 10:16:22 pm »
vrs alex has a hybrid k04 with wmi iirc  :happy2:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
« Reply #6 on: May 11, 2012, 10:19:48 pm »
Indeed and it pulls very well, Stve Jnr @ statller has one, Luke at Jabba has one.  as said lots of info on here  :happy2:
CR turbos, Turbo Dynamics, LOBA Motorsport all worth a google
Offline dan930
  • -Receive: 56
« Reply #7 on: May 11, 2012, 11:10:25 pm »
It's expensive,last time I asked its around £1400 for the hybrid
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline Jussa
  • Bicester
« Reply #8 on: May 11, 2012, 11:12:07 pm »
Who would do the custom map after the install?
« Reply #9 on: May 12, 2012, 09:29:35 am »
APR...    :wink:
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #10 on: May 12, 2012, 01:11:12 pm »
any good tuner writing his own software will do it!
Paul
Offline Tamiyoman
  • -Receive: 39
« Reply #11 on: May 12, 2012, 01:45:10 pm »
Jabba, R-tech, Apr etc, probably some others too, that offer custom software.
« Reply #12 on: May 12, 2012, 05:26:04 pm »
GIAC also have a hybrid extreme file.
There are many other things to consider if you are thinking of going for a hybrid K04 upgrade. Fuelling is one of them. The "in-tank" low pressure fuel pump need uprating (internals like the HPFP) and also RS4 injectors (you can use OEM K04, but they are limited). All these add up. :smiley:
Offline Tamiyoman
  • -Receive: 39
« Reply #13 on: May 12, 2012, 05:29:21 pm »
Think Custard Code might do them too  :ashamed:
I was talking to Luke at Jabba and he told me his ED30 K04 Hybrid is running S3 intercooler and Std Injectors, I asked if it was necessary for larger injectors and adding FMIC's and he said larger injectors were not required, uprated fuel pump was tho, he also said he was not running an additional FMIC at front and said the S3 alloy version did the job just fine and his was running 400bhp.
« Last Edit: May 12, 2012, 05:31:30 pm by Tamiyoman »
« Reply #14 on: May 12, 2012, 05:34:04 pm »
The RS4 injectors aren't a pre-requisite for a hybrid conversion, but they do make better power. I was speaking to Steve Jr at Statllers ages ago when they were doing development work with GIAC. They ran 438bhp/440lbft on their dyno and it isn't a particularly high reading dyno! (this was with WMI too!)
