Author Topic: fog grill removal  (Read 1435 times)
Offline da_ansa
fog grill removal
« on: May 12, 2012, 10:28:53 am »
happy Saturday people
I had a search on here but couldn't find anything. I was wandering how you go about removing the lower grills where the fogs are located. I want to put some lamin x on my fog lamps and haven't had the car long when I do DIY it tends to go wrong  :P
Offline mvb12
  • -Receive: 64
Re: fog grill removal
« Reply #1 on: May 12, 2012, 10:30:25 am »
Phillips screwdriver  :happy2:
1 screw in each mate  :happy2:
Offline da_ansa
« Reply #2 on: May 12, 2012, 10:43:28 am »
are the screws underneath and behind the bumper so to speak
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: May 12, 2012, 12:05:22 pm »
Nope, there is a honeycomb section that's deeper than the others. That's where the screw is  :smiley:
Once you remove the screw, stick your finger in the hole and pull the grille out
Offline Matto
  • -Receive: 116
« Reply #4 on: May 12, 2012, 12:05:31 pm »
Look into the grill/slats and you should see it. Hopefully yours won't be as bad as my GT grills. Broke a clip on both of mine they were that tight.
Offline PND
  • -Receive: 62
« Reply #5 on: May 12, 2012, 12:38:22 pm »
Assuming you've got a GTI with the honeycomb grills...
http://www.golfmkv.com/forums/showthread.php?t=140868
