Author Topic: Fitting MDI Kit in tandem with Bluetooth kit?? **solved**  (Read 2810 times)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« on: May 13, 2012, 07:05:27 am »
I have fitted a 5n0 bluetooth kit and also want to fit the MDI kit.
I have the kufatec MDI fitting loom and a plug and play bluetooth loom.
What confuses me is that the kufatec kit appears to have a blanking plug on the quad lock connector and doesnt have the pins to connect to the rest of the loom.
Quadlock from car and Bluetooth kit looks like this:
Quadlock from Kufatec MDI kit looks like this:
Which order should these looms be connected?
Is there a way to remove the blue blanking plug? WOuld it make a difference if I did?
(You can see where I have tried to pull the blue blanking plug out)
eg.
HEAD UNIT -- >  MDI LOOM -- > BLUETOOTH LOOM -- > CAR LOOM
Jason
« Last Edit: May 13, 2012, 07:09:35 am by jason_rmh »
VCDS (Preston, Lancashire)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Fitting MDI Kit in tandem with Bluetooth kit??
« Reply #1 on: May 13, 2012, 11:03:49 pm »
The order doesn't matter.  CAN is a data bus so it'll have multiple (Multiplexed) signals on one cable.
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: May 14, 2012, 05:31:57 am »
Although it doesn't matter, just make sure the loom that plugs into the stereo has the wires to for the other loom.
some MDI looms I have seen haven't had the wires for the Telephone
Cluster and Key coding
Location Great Yarmouth
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Re: Fitting MDI Kit in tandem with Bluetooth kit??
« Reply #3 on: May 14, 2012, 06:29:28 am »
That's what prompted my question. The blanking plate will not allow the  connections. The wires are there tho.
Will have a better look later and report back.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: May 14, 2012, 08:59:22 am »
I'm afraid it's a bit of a problem with these Plug and Play looms that seem to be popular now.  They aren't always fully populated.
Stu...
Offline CocoPops
    • Kennet Heath
« Reply #5 on: May 14, 2012, 12:42:39 pm »
I have Car + Bluetooth > MDI loom > Blaupunkt PnP loom > RNS510
Works fine here.
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: May 14, 2012, 12:43:46 pm »
Oh and don't I know it!!  :signLOL:
Stu...
Offline CocoPops
    • Kennet Heath
« Reply #7 on: May 14, 2012, 12:45:11 pm »
Yes, as Stu knows, it was a pain in the arse to stuff all the looms back behind the 510! :happy2:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #8 on: May 23, 2012, 06:56:48 pm »
you need an MDI compatible bluetooth loom , this is one i have fitted to a few cars
http://www.kufatec.co.uk/shop/product_info.php/info/p920_c26_Bluetooth-Handsfree---Harness----Bluetooth-Only---VW-Golf-5.html
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #9 on: May 23, 2012, 08:54:03 pm »
I bought the mdi kufatec loom. Turns out the blue thing isn't a blanking plug.
Its all fitted and working now :P
