Author Topic: RCD510 Compatibility  (Read 2574 times)
Offline callis
« on: May 13, 2012, 11:15:47 am »
Hi guys
Just a quick one, i am looking at a RCD510 on aution, ends today. Just want to make sure it would be compatible with my car.
RCD510 Part No. 3C8 035 195
vw golf gti 05 plate.
I know about the battery drain/ canbus etc, just need to make sure this RCD510 is compatible, as heard that the newer mk 6 RCD510 are not compatible.
daron.
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline johnhol78
Re: RCD510 Compatibility
« Reply #1 on: May 13, 2012, 01:58:55 pm »
Hi guys
daron.
Was it the one which wouldn;t work with an iPod.....he thought it was because it came form an MK6????
If so then I think it's an actually issue with the stereo or iPod lead he's using. Nothing to do with the stereo coming from a MK6.
Offline callis
« Reply #2 on: May 13, 2012, 02:59:32 pm »
Not sure, i remember seeing one on the BAY with something along those line, ut not sure if it was this unit im looking at.
However some other autions state that the new model 08 onwards may not fit into older golfs?
Again im not too sure.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: May 13, 2012, 03:06:23 pm »
all of them fit, just some of the function may not work
DAB - unless you add the antenna
More than likely they will need coding
any car with an old gateway will have battery drain
Cluster and Key coding
Location Great Yarmouth
Offline bakili
« Reply #4 on: May 13, 2012, 03:07:21 pm »
My RCD 510 DAB came of 2011 MK6, fitted to 2008 MK5 without any issues and no canbus upgrade or coding.
Offline callis
« Reply #5 on: May 13, 2012, 03:08:10 pm »
I thought that was the case. and i will be ordering a canbus of you eddie as soon as i get my stero.
Cheers guys.
