Author Topic: R32 - S3 brake disc replacement  (Read 1057 times)
Offline Sammy
GTI MK5 with all the gooodies
K04 power going on soon!
Offline DFish
Re: R32 - S3 brake disc replacement
« Reply #1 on: May 13, 2012, 04:17:39 pm »
Depends if you want discs that last. The only drilled discs worth having as those that have them cast in and not drilled after the fact. Cracks galour. :(
Go either plan or grooved if you have to have a pretty pattern.
Fish
Offline Ree
« Reply #2 on: May 13, 2012, 08:35:53 pm »
I have neuspeed disc with yellow stuff pads on my R, see my sig.
These are drilled in way to help negate cracking, I have had them for about 5,000 miles no issues !
Contact Mike at Awesome gti !
« Last Edit: May 13, 2012, 08:37:34 pm by Ree »
Offline W8 Performance
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
« Reply #3 on: May 13, 2012, 09:30:03 pm »
Speak to DaveB and get discs from him. Job done.
You do get some droning with drilled and grooved discs and as others have said some drilled discs are prone to cracking.
At then end of the day if its cheap then you will be buying more in the near future :happy2:
Offline Sammy
« Reply #4 on: May 13, 2012, 09:44:01 pm »
Does dave b supply normal brake discs or drilled ones? Also how much?
