Author Topic: What needs changing regularly or at intervals?  (Read 1032 times)
Offline xreyuk
« on: May 13, 2012, 08:48:06 pm »
Hey guys,
I'm just going through making a list so I can remember, what needs changing regularly at intervals to keep the car running at it's best?
I have a Seat Leon 1.6TDI CR Ecomotive and the only things I can think of are:
Cambelt + Coolant/Water pump (are these pumps the same thing, I've seen both referred to) - Every 4 years or 120,000miles (according to my book)
Brake Fluid - Every 2 years
Air Con Service - Every 2 years
Engine Coolant - Every 2 years
Brake Pads/Discs and Tyres - As required
Gearbox Oil - 100,000 miles
Oil, Oil Filter, Pollen Filter - Every Service (based on 10k miles servicing)
Air Filter, Fuel Filter - Every other service (based on 10k mile servicing, if I change to variable servicing should I do this every service?)
Anything I have missed, or you guys would recommend changing?
Offline Pashka
Re: What needs changing regularly or at intervals?
« Reply #1 on: May 29, 2012, 04:17:51 pm »
Only OEM Cambelt/pump is charged for 120k. If not OEM, you should change it on 60-80k. For my safety, i do it on 60k.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline xreyuk
« Reply #2 on: May 31, 2012, 12:58:18 am »
Cheers.
It's currently OEM pumps, and all future ones will be. Thanks.
