Author Topic: Latest firmware for RNS510 + Maps?  (Read 4273 times)
Offline CocoPops
    • Kennet Heath
« on: May 14, 2012, 12:44:28 pm »
I've not updated my firmware/maps since March last year.
How can I check what firmware/maps I have and how can I get the updates if needed.
I know I have the modded speed camera map, but no idea on the version!  :signLOL:
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Latest firmware for RNS510 + Maps?
« Reply #1 on: May 14, 2012, 01:05:45 pm »
Press and hold setup for about 30secs. If the test menu is enabled you can find your map and firmware version in there. If it's not you will need someone with VCDS to enable the menu for you.
Latest firmware will depend on what version unit you have.
Latest maps are V8
Offline CocoPops
    • Kennet Heath
« Reply #2 on: May 14, 2012, 01:19:44 pm »
Excellent.
Will give that a go. I think it has been enabled. The 510 was exHedge when he swapped to the Czech Missile.
« Reply #3 on: May 14, 2012, 01:54:32 pm »
Think that was V7 maps Lee and 26xx firmware.
Offline CocoPops
    • Kennet Heath
« Reply #4 on: May 14, 2012, 01:56:46 pm »
Excellent, that answers part 1 then :)
Firmware, I see the thread above so will look at that.
Speed Camera modded v8 maps?
« Reply #5 on: May 14, 2012, 02:01:23 pm »
You can't ask for them here Lee as VW are very hot on these things. I believe they are available from the dealers.  :wink:
Offline CocoPops
    • Kennet Heath
« Reply #6 on: May 14, 2012, 02:05:37 pm »
I thought that might be the case Ian.
I'll get down to the stealers and see what they say.
Offline CocoPops
    • Kennet Heath
« Reply #7 on: May 15, 2012, 08:56:53 pm »
Wish me luck.... the 3810 firmware is currently flashing  :surprised:
Offline CocoPops
    • Kennet Heath
« Reply #8 on: May 15, 2012, 09:35:53 pm »
Bollocks!!
Firmware update fine but it wiped my map :(
Luckily I have my orginal disc from 2008, but it's an old map. I assume this will work in the interim until I can get a new map?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #9 on: May 15, 2012, 10:06:27 pm »
Bollocks!!
Yes will do.
Is that a V4 or V5 disc?
Offline CocoPops
    • Kennet Heath
« Reply #10 on: May 15, 2012, 10:09:06 pm »
V3 :(
I'm in need of a DL DVD as well, because single layer ones that I have are too small.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #11 on: May 15, 2012, 10:21:41 pm »
Not cheap to buy I'm afraid.
Where are you located?
Offline CocoPops
    • Kennet Heath
« Reply #12 on: May 16, 2012, 09:59:06 am »
So my old map works (just running from DVD temporarily) with 3810 firmware.
I do like the new "route" colours with the logos that show shortest/fastest/most economical.
I never knew which was which last time.
Offline CocoPops
    • Kennet Heath
« Reply #13 on: May 16, 2012, 01:19:01 pm »
v8 Maps are being loaded as we speak :)
Amazing how you take the full postcode for granted... I was stuck this morning when I couldn't use full postcodes.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #14 on: May 16, 2012, 02:37:42 pm »
 :pomppomp: :pomppomp:
