Author Topic: 9.5J on the rears?  (Read 6059 times)
Offline Sharif
9.5J on the rears?
« on: May 14, 2012, 06:39:55 pm »
Hi all,
Considering refurbing the Mams I have and running them on my MK5.
Specs are 8.5 on the fronts ET45, 9.5 on the rears, ET 35, PCD 5x112. Current tyres on them are 235/35/19.
Would the wheels fit ok on the current tyres, or would I need to change them? I have 225/35/19s on my lm reps which I could swap over.
And would the rears poke?
Thanks,
Sharif
Offline jameelno1
  • TDI Power
Re: 9.5J on the rears?
« Reply #1 on: May 14, 2012, 10:19:32 pm »
you will have a lot of poke im running et35 8.5 and i poke u will have to do the fender screw mod and probably need to roll your arches to try and prevent rubbing
golf mk5 1.9 tdi
Offline AmaZak
« Reply #2 on: May 20, 2012, 09:28:33 pm »
Sharif,
You would be ok up front slammed or not with ET45, rears : depending how low you wanted to go the rears will rub unless you  add the following,
option 1 dial in some camber
option 2 run 225's at the back for some added stretch.
Or both of the above will work really well.
Here is mine with 19x8.5 19x9.5 ET35 all round 215/35/19 up front 235/35/19 rears, did rub at the back causing some damage on the arches as well but I was not running any camber at the time.
« Last Edit: May 20, 2012, 09:32:32 pm by AmaZak »
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: May 20, 2012, 09:30:04 pm »
fronts you'll be fine with
rears you'll struggle with without camber and things
you'll need thinner tyres
« Last Edit: May 20, 2012, 09:32:34 pm by sub39h »
PLANS: Stage 2+
Offline AmaZak
« Reply #4 on: May 20, 2012, 09:44:00 pm »
You can also tuck them  :happy2:
Offline Sharif
« Reply #5 on: May 21, 2012, 04:45:16 pm »
Thanks for the help guys, now to decide whether to run them.
