Author Topic: Do all factory xenons come with headlight washers. *UPDATE*  (Read 5573 times)
Offline driver rider
  • -Given: 18
I feel silly had the car two and a half weeks.  i've just noticed that though the xenons on my car appear to be factory fit. They don't have headlight washers.  I thought xenons always have washers due to EU laws?  I haven't had any road users flash me whilst using the xenons.
« Last Edit: June 04, 2012, 05:34:21 pm by driver rider »
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Do all factory xenons come with headlight washers.
« Reply #1 on: May 14, 2012, 07:07:33 pm »
They are OEM then that someone has retrofitted. Just not finished the job off.
VW would not release a car with factory fit Xenon's without Headlight washers. As you say it is EU Law :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: May 14, 2012, 07:07:59 pm »
they should have washers  :happy2:
PLANS: Stage 2+
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #3 on: May 14, 2012, 07:08:19 pm »
Certainly would have left the factory with headlight washers, which came with all stock cars that have Xenons. The washers themselves are part of the winter pack, so some cars had them that ran halogen headlights.
The beam pattern leveling is done by the auto level kit which factory Xenon cars also should have.
I'd put money on the previous owner of your car having retrofitted Xenons to your vehicle(?) with the standard bumper in place etc... :happy2:
Pete
  • -Given: 380
  • -Receive: 442
« Reply #4 on: May 14, 2012, 07:23:54 pm »
Won't there be a problem with MOT if a car has Xenons but no washers?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: May 14, 2012, 07:25:02 pm »
No.
They only have to work IF fitted.
As long as the beams are all correctly aligned they will be fine.
  • -Given: 18
« Reply #6 on: May 14, 2012, 07:51:59 pm »
What exactly does the winter pack entail as going by the spec of my car I WAS pretty sure I've got that spec.
Where would I go to finish the job off and how would I do it?  Im glad it won't affect the MOT.  The headlight beam is fine the beam goes up and then down as I switch them on.  Ive seen the headlamps "auto level" when going along roads.
I really am gutted.  I passed up on many nice examples simply because they didn't have xenons.  Then this happens.  Im a bit cheesed with myself.
Thanks for the help though guys.  Much appreciated.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Do all factory xenons come with headlight washers.
« Reply #7 on: May 14, 2012, 07:56:03 pm »
Sounds like you have auto levelling then so just the washers are missing.
Maybe the previous owner removed them or replaced the bumper and not the washers.
Check if the wiring is in place behind the bumper?
Might not be so bad. You may just have to fit and connect the washers?
Jas
VCDS (Preston, Lancashire)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=lh413s6facfki7442h98lui5co&/topic,19740.0.html
« Reply #8 on: May 14, 2012, 07:58:49 pm »
Its easy to tell if they are retro fitted... just look for a connector like this...
.. connected into the back of each headlight.
  • -Given: 18
« Reply #9 on: May 14, 2012, 08:25:13 pm »
Jas
Hi I'll have a look behind the bumper and see what I can see.
I'll have a look for that kind of connection. Thanks
  • -Given: 18
« Reply #10 on: May 16, 2012, 07:34:21 pm »
Sorry guys... on my polo I could adjust the level of the headlight beam.  I can't do the same on my car.
Does this mean I've got factory fit xenons? Do all GTI's not have the ability to adjust the headlight beam up or down or is this specific to factory equipped xenon cars?  I can adjust the brightness of the dials  on the dashboard (like on my polo) but theres definitely no way of doing adjusting the level of the headlight beam on my GTI, though I can adjust the brightness of the dials.
Thanks in  advance!
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #11 on: May 16, 2012, 07:39:28 pm »
Thanks in  advance!
Only halogens have headlight adjustment where as xenons would have an auto levelling kit as standard from the factory
Saintsteve
« Reply #12 on: May 16, 2012, 07:40:01 pm »
Cars origonally equiped with Halogens have a manual spin roller switch which adjusts height adjustment along with a Dashboard light cluster dimmer roller switch.If you car now has Xenons, that switch will be un-useable and potentially an MOT failure if left installed.
Your best bet is to get a new Dash surround thats fitted with factory fit Golf xenons, so the switch is not visable on your dashboard to the MOT inspector.
I am doing the very same thing currently, so i have no worries come MOT time Nxt january 2013.
  • -Given: 18
« Reply #13 on: May 16, 2012, 08:17:06 pm »
Thanks in  advance!
Thats what I thought. Thank you for a massively helpful post.
Thank you. I have no spin roller on my dash.  Only a dashboard dimmer switch.  So thankfully I have nothing to uninstall! Which is a relief.  I will now get to the bottom as to why my car has no headlight washers or perhaps they're not working?  I'll keep you posted.  Thanks again for prompt and helpful replies.  :drinking:
Offline Kalpsn2000
  • -Receive: 56
« Reply #14 on: May 16, 2012, 09:01:27 pm »
OP based on your sig you list heated seats which I thought was part of the winter pack which should mean you have the headlight washers also (I dont have either so correct me if i'm wrong).
Also you can tell from your bumper if you have headlight washers, the strip below the headlight will be split in to two bits.
EDIT:
Just noticed you have leather seats so they come heated as standard so my 1st point is probably moot.
« Last Edit: May 16, 2012, 09:03:50 pm by Kalpsn2000 »
