Author Topic: Head unit swap  (Read 1713 times)
Offline vRS_Pagey
  • -Receive: 59
Head unit swap
« on: May 15, 2012, 02:37:15 pm »
Guys, can anyone confirm if I can replace my MFD2 for an RCD/RNS 510 without changing the CANbus or anything else?  The car is a MY2007 Golf GT with highline display.  Also, am I right in thinking the difference between the RCD and RNS is the later has Sat Nav?
Cheers, Lee.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Head unit swap
« Reply #1 on: May 15, 2012, 03:02:29 pm »
No way of knowing if you will get Battery drain however i haven't seen a 2007 reg car with a lower than K revision Gateway so you "should" be ok.
Otherwise it is a straight swap
Yes only difference is RNS is Satnav (Radio Navigation System vs Radio Compact Disc)  :happy2:
Offline bakili
Re: Re: Head unit swap
« Reply #2 on: May 15, 2012, 05:14:40 pm »
My car is 57 but 08, can g/w part number is finishing with 530L, no battery drain issues.
Sent from my Galaxy Nexus
Offline skard
  • -Receive: 245
Re: Head unit swap
« Reply #3 on: May 15, 2012, 05:23:52 pm »
Our Altea (not a Golf, I know) is an 07 and has the K gateway with 0170 software and should(?) suffer from battery drain, whereas a K with 0178 software is the first of the compatible versions, I believe.
Only way to check is a scan and the software version is shown in 19-CAN Gateway
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_%28RNS510%29_Retrofitting
Offline Pashka
Re: Head unit swap
« Reply #4 on: May 29, 2012, 04:41:54 pm »
Mine one made on 06-10,having no drain issues.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
