Author Topic: Sky Fibre Unlimited  (Read 2430 times)
Offline PND
  • -Receive: 62
Re: Sky Fibre Unlimited
« Reply #15 on: June 01, 2012, 01:51:46 pm »
Within 2 years for mass launch. Problem is with VM, they are using coax cable which limits their capabilities. Eventually Sky WILL be using fibre to supply your TV, so using the satellite dish is gonna be fazed out altogether.
everything up 1 single fibre optic cable at your doorstep..  :happy2:
Is this only going to possible with FTTH and not FTTC?  My block-paved cul-de-sac is too nice to dig up!
The blade that is used to cut is 3mm in width. Unfortunately it has to be done, but a lot better then a spade and shovel that VM currently use..
Sounds about right!  In the meantime, 37MB will do nicely!  Thanks for the info.
« Reply #16 on: June 01, 2012, 01:55:15 pm »
Well Virgin Media's network runs Docsis 3 so 200 MB/s is possible.  :smiley:
