Hey folks ,
Probably a question that has been asked a few times before ,I have searched for it and still been scratching my head over the right way to go... probably just confusing myself.
What I am basically doing is looking around a replacement clutch before I start modifying my car in any real major way.
My car is an 04 GT TDI (140 ) which i believe is the BKD engine code if that helps y'all. Has just about covered 90k Miles in a non modified state , and too my knowledge hasn't had the clutch changed in that time.
Ive always had an opinion of its better to be safe than sorry when it comes to anything mechanical , id rather get it done right by a pro then have it bodged together by some monkey.
Im looking to get my car up to around the 170-190 BHP mark, which will probably take the shape of a Re-Map and Turbo Back Exhaust , and as i say to handle that power i want to get the clutch done before anything else , and probably the flywheel too ( Better safe than sorry )
I guess my question takes on many angles , some people have said to keep with the stock setup and it will be fine , which is a view i accept but cant help the niggling thought in my mind that its done 90k and hasnt been changed...
Ive been looking around at the various options that people have been suggesting so far and as of now i have found the following.
http://www.darksidedevelopments.co.uk/products/southbend-silent-single-mass-flywheel-clutch-kit-for-vw-02q-6-speed-tdi.htmlhttp://www.darksidedevelopments.co.uk/products/sachs-2-0-tdi-6-speed-02q-dual-mass-flywheel-and-clutch-kit.htmlhttp://www.awesomegti.com/parts/transmission/clutch-and-flywheel/helix-road-clutch-kit-golf-mk5-2-0-gt-tdi-eng-azv-bkd-bmm-2006Im basically looking for a clutch setup that i can have installed and then basically forget about.
So please excuse my rambling and probably being asked the same question again...
What would people advise I do ?
What setup should i go for based on how i plan to upgrade other things ?
What would people do if in my situation ?
If people have already done similar clutch upgrades , what are your opinions , real world reviews ?
thanks in advance for any answers you choose to give people , they will be most appreciated !
John
p.s allthough my name suggests it im not assocaited with DarkSide Developments , im just a nerd !
![nerd :nerd:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/nerd.gif)
