Author Topic: Just done the K04 conversion OMG!  (Read 9310 times)
Offline Sammy
« Reply #15 on: May 17, 2012, 04:53:30 pm »
Just got booked in to R tech for the 11th of June a very long wait  :sad1:
Dont know how i am going to have my car like this for 4 weeks!
GTI MK5 with all the gooodies
K04 power going on soon!
Dsg steel
Re: Just done the K04 conversion OMG!
« Reply #16 on: May 17, 2012, 05:23:11 pm »
Hi sammy
Good to see you got it all fitted now :happy2:
How much roughly did all the turbo kit and fitting cost you?
I'm looking to do the same and take it back to R-tech for tuning.
Billy
Offline Tamiyoman
  • -Receive: 39
Re: !!!!
« Reply #17 on: May 17, 2012, 05:25:53 pm »
I know the feeling, my car is going to R-tech next thursday for DSG remap then I have to wait until 12th June before I can get back to Jabba for map tweaks, so I wont be able to use the extra 800rpm until the map is completed  :sad1:
Offline alackofspeed
  • -Receive: 24
« Reply #18 on: May 17, 2012, 05:42:38 pm »
Might be worth checking on VCDS that you're not doing anything really nasty to the car. That said perhaps the engine will be sufficiently protected with the MK5 ECU even if running oddly?
I've seen the ill effects of a bad map on other turbo-charged engines running standalone, and it is not pretty! Were it me, I'd exercise caution.
Offline james
« Reply #19 on: May 17, 2012, 05:50:01 pm »
i would of booked it into r-tech befor getting the turbo installed lol.
i have decat, bsh throttle pipe, Turbo Discharge Kit, THS IC
« Reply #20 on: May 17, 2012, 05:56:34 pm »
Turbo discharge & BSH TB pipe gains are very minimal, every little helps  :smiley:
Offline Sammy
« Reply #21 on: May 17, 2012, 05:56:43 pm »
Damn doesnt sound good for me at all then, I hope i am not damaging the engine or anything for that matter really hope not, Got very worried just now was in traffic and the car just started shaking and i went straight to the garage and the mechanic who fitted the turbo says it may not be a misfire and more like a piston due to upgrading injectors without the map  :scared:
Luckily it wasnt that and was down to the spark plugs, These were changed roughly about 7 months ago (NGK R) but i dont know if the map has totally shortened the life of it.
Offline Sammy
« Reply #22 on: May 17, 2012, 05:59:54 pm »
Hi sammy
Billy
If i break it down
K04 turbo almost new from 10 plate S3 with 9k miles on the clock  £350 - Ebay
S3 Intercooler £90 - Ebay
K04 pipes and other parts required to fit - VRS Alex from the forum
Labour charge -  £300 All in
So looks like £1020 + charge for remap
Offline james
« Reply #23 on: May 17, 2012, 06:00:35 pm »
i dunno, when u start getting the power up there the free flowing makes a big diffrence mid range.
« Reply #24 on: May 17, 2012, 06:08:06 pm »
The sFs versions were dynoed showing a 4hp improvement.  Felt bugger all difference on mine with neuspeed turbo discharge pipe, will fit a new TB pipe for the sake of any slight gain that might be had.  Ive given up on trying to get a BSH one.  Im confident I could have a nicer one fabricated  :smiley:
Offline james
« Reply #25 on: May 17, 2012, 06:18:06 pm »
you having trouble gettin one then?  i just orderd of the US site, it took 2 weeks.  you cant even see it lol.
« Reply #26 on: May 17, 2012, 06:21:54 pm »
Just not keen on BSH stuff, the drop links are turd, the Catch can doesn't look as well thought out or made as the (allbeit more expensive) Forge or DD42
I was on the lookout for a used one & Dubteks service was dire.  Will have one made I think
Offline james
« Reply #27 on: May 17, 2012, 06:24:27 pm »
i just sold a Neuspeed Hi-Flow Intercooler Pipe for £50,  as i needed a meth hole.  Shame i did not know you wanted one dude.
« Reply #28 on: May 17, 2012, 06:29:03 pm »
What was clearance like as ive heard most variants are very close to the fans? tis a shame  :sad1:  With any luck the buyer wont get round to fitting  :evilgrin:
Offline james
« Reply #29 on: May 17, 2012, 06:32:30 pm »
very tight the BSH one was better.  It is fine if you dont have the THS IC
nick at r-tech had it..  going in his mk4 lol.
