Author Topic: low pressure fuel pump  (Read 6597 times)
Offline james
« on: May 17, 2012, 10:25:34 am »
Silly question, where is it located?   and where can you get an upraded version?
Re: low pressure fuel pump
« Reply #1 on: May 17, 2012, 10:33:19 am »
You have to remove your rear seat to access it and afaik only one outfit in the US have an uprated version.
Offline james
« Reply #2 on: May 17, 2012, 10:36:13 am »
do you know the part number? and how much they are?
« Reply #3 on: May 17, 2012, 10:55:57 am »
Best person to ask is heavyd as he replaced his lpfp a few months ago.
« Reply #4 on: May 17, 2012, 11:00:49 am »
This posting suggest the latest version lpfp is 1K0 919 051 DB.
http://www.golfmkv.com/forums/showpost.php?p=3117803&postcount=12
Offline james
« Reply #5 on: May 17, 2012, 11:04:24 am »
thanks for that  :happy2:
Offline heavyd
  • -Receive: 29
« Reply #6 on: May 17, 2012, 12:01:42 pm »
I bought a 1k0919051db last november
sorry cant remember how much it was, but its only a half hour job to change, hardest part is getting the rear seats out!
is there any particluar reason why you are after a new one?
Offline s3dubbin
« Reply #7 on: May 17, 2012, 12:18:06 pm »
Uprated one is USP Motorsports. Their piggyback system is about £400. Absolute arse to install. Stevie.
Offline james
« Reply #8 on: May 17, 2012, 01:47:52 pm »
was recommed at the power im running,  so thought it would be best to change it.
« Reply #9 on: May 17, 2012, 04:34:31 pm »
Did you actually log the lpfp output pressure over the rev range before coming to that conclusion?
Offline james
« Reply #10 on: May 17, 2012, 05:46:00 pm »
hmm no  :chicken:   what blocks do i need to log.  does it not have to stay at 5?
« Reply #11 on: May 17, 2012, 05:59:46 pm »
log block 103.
5 bar seems to be constantly mentioned over the internet but I think if you can maintain 4.5 bar minimum over the entire rev range then you should be supplying enough petrol to the fuel rail.
Offline james
« Reply #12 on: May 17, 2012, 06:03:16 pm »
ok i will give it a blast in a min.
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: May 17, 2012, 09:26:31 pm »
There is one other lpfp option.  I can do an intank Bosch 044 upgrade.  It will hold 6 bar at 7.5k with a 3076 so its more than good for the job.
Follow AKS tuning on Facebook
Offline Thor
  • -Receive: 25
« Reply #14 on: May 18, 2012, 09:02:40 am »
Don't forget that your standard fuel filter is only rated to 6.4bar  :happy2:
                                     Mk6 GTI
