Author Topic: Which spark plugs for K04 stage 2+  (Read 8876 times)
Re: Which spark plugs for K04 stage 2+
« Reply #15 on: May 17, 2012, 06:57:58 pm »
Sammy you got to hit the thank you button for Mike after all that, he did everything bar fit the things  :grin:
 :grin:  Got my plug socket ready!  :grin:
Offline DonalM
« Reply #16 on: May 17, 2012, 07:00:51 pm »
I'm running the NGK 8's like Mike has posted above.
Only have them in for 2 days though(300 odd miles), but no issues so far.
http://www.mk5golfgti.co.uk/forum/index.php/topic,31784.0.html
TR DSG Gti- K04, TTRS Brakes, BBS, H&R, RNS, Xenons, Leather, Ed30 Front lip, US Smooth Grill, RVC, Miltek, WALK, Loads of Forge bits + lots more.
« Reply #17 on: May 17, 2012, 07:15:18 pm »
Am I the only one in thinking that he should vcds scan/log thew car for misfires as maybe, just maybe,  this isn't a plug issue.
Offline martziniuk
« Reply #18 on: May 17, 2012, 07:24:47 pm »
I'm thinking he should definitely be logging the car! After fitting a K04 and injectors and running a K03 map he'd be mad not to.
I put my K04 map on before I even started the car.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #19 on: May 17, 2012, 07:33:39 pm »
Nology Silver plugs gapped adjusted to the application.   I have cured many misfire issues with these on high power TFSI engines.
Nick
01455 617233
Offline flyboy1976
« Reply #20 on: May 17, 2012, 07:43:46 pm »
Any chance of the Nology part number that equates to a heat range 8 NGK plug Nick
« Last Edit: May 17, 2012, 07:46:53 pm by flyboy1976 »
« Reply #21 on: May 17, 2012, 07:45:01 pm »
As above please. :)
Offline R-tech-Nick
  • -Receive: 30
« Reply #22 on: May 17, 2012, 07:52:00 pm »
Dont ask me!! I just phone my supplier and tell them what I want, if they want the sale the do all the hardwork for me.. :innocent:
I use http://www.theperformance.co/brand_nology.asp
http://www.nology.com/silver.html
Nick
01455 617233
Offline vRSAlex
  • -Receive: 253
« Reply #23 on: May 17, 2012, 07:57:01 pm »
The Nology plugs are meant to be really good.  Around a tenner a plug iirc.
I have the BKUR7ET plugs in mine.  Teff also runs them in his 'R'.
If you are doing short trips then the 8's dont burn as well as the 7's.
Follow AKS tuning on Facebook
« Reply #24 on: May 17, 2012, 08:03:09 pm »
So there's a nology 8 plug alex?
Offline Sammy
« Reply #25 on: May 17, 2012, 08:16:28 pm »
Nick
Nick you have a PM  :smiley:
GTI MK5 with all the gooodies
K04 power going on soon!
Offline bobsey
« Reply #26 on: May 17, 2012, 10:02:06 pm »
I had one of the Ngk 8's randomly fail on my stage 2+ eddy. Causing multiple missfires, got standard Ngk's in now which I had no problems before changing to these.
« Reply #27 on: May 17, 2012, 11:09:12 pm »
Was the plug fouling and do you do lots of short journeys?
Offline Sammy
« Reply #28 on: May 17, 2012, 11:17:45 pm »
I am mostly in city driving does that mean  should go for the 7 plugs?  :confused:
Quite confused on what to go for now and with my car misfiring i need some ASAP, What should i go for someone help please!
« Reply #29 on: May 18, 2012, 12:08:52 am »
Given your driving habits, I would go for the 7 plugs.
