Author Topic: Is it safe to drive car after fitting S3 Injectors without remap  (Read 6611 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: Is it safe to drive car after fitting S3 Injectors without remap
« Reply #15 on: May 19, 2012, 09:25:39 am »
on the basic rail pressure they flow around 13-16% more which the ecu fuel trims should take care off until remapped with the S3 injector setting.  To see if your in a safe window you will need to check your long term fuel trims on blocks 032 to make sure its with  in range.
01455 617233
