Author Topic: Mercedes brake discs  (Read 1305 times)
Offline ktlstar
« on: May 18, 2012, 11:49:31 am »
I am after 330mm x 28mm discs but having no luck finding any information. :fighting:
Will these work with the MK5 golf ?
Here are the specs.
Golf mk5:
Diameter: 312.0 mm
Thickness: 25.0 mm
Minimum Thickness: 23.0 mm
Height: 50.0 mm
Bore Diameter: 65.0 mm
Number of wheel studs: 5
Number of locating studs: 112
Mercedes c class:
Thickness [mm]: 28,0;
Type: Perforated / Vented;
 Centering Diameter [mm]: 67;
Diameter [mm]: 330;
Height [mm]: 46,5;
Hole Arrangement / Number: 05 / 07;
Minimum Thickness [mm]: 26;
Pitch Circle Ø [mm]: 112
To me it seems good, just 2mm difference on the center bore which i now can get some sort of spigot ring to sqweeze in there if it will effect performance.
« Last Edit: May 18, 2012, 12:04:04 pm by ktlstar »
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline DFish
Re: Mercedes brake discs
« Reply #1 on: May 18, 2012, 02:44:06 pm »
My guess is that you'd need to space the caliper out so that they would fit over the larger disk. Might be easier to find an S3/R32/Cupra setup.
Fish
Offline ktlstar
« Reply #2 on: May 18, 2012, 08:27:19 pm »
I have porsche calipers already howver i need 330mm discs. If only there was a brake guru.  :signLOL:
Offline jimk04
« Reply #3 on: May 18, 2012, 10:50:55 pm »
Search for my '330mm brake conversion' or look up jims shadow blue gti in the members rides.
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline ktlstar
« Reply #4 on: May 20, 2012, 03:18:05 pm »
All sorted thanks to Jim! Top bloke  :happy2:
