Author Topic: Nearly put my fist through my stereo..please help!  (Read 1301 times)
Offline biGTIme
« on: May 18, 2012, 10:07:58 pm »
Hello guys,
Newbie here. Ok..satnav/stereo locked after battery replacement, code screen came up, looking in my booklet ful of accumulated s hit from previous owner, punched in the code...nothing. Next day went to vw and they plugged there gear in..still nothing. Two coffees later the teck comes back and tells me the code is not being accepted for some reason. Wtf is going on? What are my options?
05 gti with cd changer and nav
Any input will be much appreciated
Thanks,
R
Offline skard
  • -Receive: 245
Re: Nearly put my fist through my stereo..please help!
« Reply #1 on: May 18, 2012, 10:20:57 pm »
Try http://uk-mkivs.net/forums/t/317927.aspx
On some other brands (thinking of Vauxhall here), it used to be the case that every wrong attempt resulted in having to leave the stereo & ignition on for double the time before trying again, so after about 9 attempts you'd have to leave it on for a couple of hours!
Give it a bash? If you do, make sure you have headlights, aircon etc turned off to preserve the battery.
Offline biGTIme
« Reply #2 on: May 18, 2012, 10:34:49 pm »
Thanks mate,
The issue is that I have the code but its not being accepted. The car is NOT in safe mode either.
Offline skard
  • -Receive: 245
« Reply #3 on: May 18, 2012, 10:35:57 pm »
Has the code been changed possibly?
Offline biGTIme
« Reply #4 on: May 18, 2012, 10:40:45 pm »
Possibly.
Other than the code not being accepted, what else could confirm that? Is it even possible to reprogramme?
Thanks,
Offline Russ_leeds
« Reply #5 on: May 18, 2012, 10:51:14 pm »
could you not take it to a car stereo shop, and they could maybe unlock it for you? (I know of 1 or 2 in Leeds that can do so)
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline skard
  • -Receive: 245
« Reply #6 on: May 18, 2012, 10:53:36 pm »
Possibly.
Thanks,
I would say if you leave the stereo and ignition on (untouched) for over an hour then input your code and it doesn't accept it - then there's a chance your code has been changed.
A car audio specialist could probably reflash it, as suggested above.
