Author Topic: Is this normal  (Read 1846 times)
Offline aledbeswick
Is this normal
« on: May 19, 2012, 06:14:20 pm »
I installed a new PCV, revision D DV and bluefin map yesterday and the extra pull is fantastic. However, turbo lag now seems massive, as if there is nothing below 2.5-3k revs then suddenly massive amounts of power, then when changing gear (manual) there is another lag before the turbo kicks in again.
Is this normal? I will do some logging tomorrow to check that everything is ok, what should I be looking at: MAF, requested boost, actual boost, N75?
Thanks!
