Author Topic: SUBFRAME BOLTS  (Read 1367 times)
Offline gtlee
SUBFRAME BOLTS
« on: May 19, 2012, 06:19:12 pm »
I've purchased the bolts and its time to fit them,what jacking points do you guys use?
The jacking point that I normally use are under the rear wishbone thats need undoing.
lee.
« Last Edit: May 19, 2012, 06:29:39 pm by gtlee »
Golf V 5DR DSG GT Sport,,Xenons,Full leather,18'Charlestons,Lux pack,storage pack,folding mirrors,front armrest, retrofited--mk5 gti  grilles,fog lamps grilles,GTi rear bumper,coloured coded sideskirts, VIM RNS-510 C,MK6 MFSW with paddles,GTi DSG gear lever,Cruise control,Highline.Rain sensor with window auto closure,TPMS.7P6 Bluetooth.
Mods to come: RVC, and.................
Offline DFish
Re: SUBFRAME BOLTS
« Reply #1 on: May 19, 2012, 08:09:25 pm »
Depends if you're using a trolley jack or not. If you are using the OE supplied instead then you'd be jacking up on the seals, which you can then place you're axel stands as close too as possible. Could be wrong though.
Fish
Offline gtlee
Re: SUBFRAME BOLTS
« Reply #2 on: May 19, 2012, 08:32:28 pm »
It'll be trolley jack as normal and have due to past experience don't really trust the original jacking points on the car as they tend to get damaged.
Might have to use a block of wood with axle stands on each side.
All done now. :wink:
« Last Edit: May 20, 2012, 03:53:12 pm by gtlee »
Offline RobboGTI
Re: SUBFRAME BOLTS
« Reply #3 on: May 25, 2012, 04:58:52 pm »
How did u do this in the end mate?
