Author Topic: faukt code  (Read 1726 times)
Offline meady
faukt code
« on: May 20, 2012, 02:16:22 pm »
Had my car scanned today by gti265 and had this fault code come up, does anyone have a rough idea of the cost to fix this and if it needs to go to a vw garage or can any decent garage do it, cheers
1 Fault Found:
000801 - Engine Speed Sensor (G28)
               P0321 - 008 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 111142 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:03:39
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: faukt code
« Reply #1 on: May 20, 2012, 02:21:30 pm »
Ross Tech's Wiki has some info on this one
http://wiki.ross-tech.com/wiki/index.php/16705/P0321/000801
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: faukt code
« Reply #2 on: May 20, 2012, 02:23:18 pm »
Also If you can give us some more details on the car (like age, engine code, etc) then it will be possible to look up the price of the past etc.
Offline meady
Re: faukt code
« Reply #3 on: May 20, 2012, 02:24:37 pm »
its a 56 plate golf gti, whereabouts would i find the engine code, cheers
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: faukt code
« Reply #4 on: May 20, 2012, 02:25:57 pm »
Sticker in the boot will have the code, I am pretty sure it will be an AXX on a 56 plate.
Offline meady
Re: faukt code
« Reply #5 on: May 20, 2012, 02:31:38 pm »
couldnt find a engine code but the chassis number isWVWZZZ1KZ7W004595 if that is any help
Offline meady
Re: faukt code
« Reply #6 on: May 21, 2012, 05:32:31 am »
Could it possibly be anything to do with a cambelt change about a month or so ago ??? Als does anyone know where the engine speed sensor is and if it is possibke to make sure there is a good conection on it without taking things apart. Cheers
Offline edd666999
  • -Receive: 89
Re: faukt code
« Reply #7 on: May 21, 2012, 06:42:25 am »
was this code cleared and it then re occurred?
Offline meady
Re: faukt code
« Reply #8 on: May 21, 2012, 06:44:50 am »
I think hr tried to clear it but it was still there when the car was started bk up
Offline gti265
Re: faukt code
« Reply #9 on: May 21, 2012, 02:35:00 pm »
Yep cleared then started engine up and it came back up
Tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline meady
Re: faukt code
« Reply #10 on: May 24, 2012, 10:01:13 pm »
well got the car back today, all it needed was a new speed sensor. Only cost me £60 so not to bad really.
Only thing was the bloke that fixed it told me the car had been involved in a front end hit and the radiator hasnt been fitted back properly. So because of this the top brackets holding it on arent secured so the top is leaning towards the engine. That means im going to need to get it fixed as it is leaning very close to one of the boost pipes and the last thing i want is for one of them to get damaged and costing me an arm and a leg to get fixed.
All seems to come at once and when you never have any spare money :)
