Author Topic: Geometry changed to help 50p tyre wear?  (Read 731 times)
Offline neil86
« on: May 20, 2012, 07:59:31 pm »
Would you reduce the rear toe in or anything to stop the uneven tyre wear on inner edge?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Geometry changed to help 50p tyre wear?
« Reply #1 on: May 20, 2012, 08:33:11 pm »
Reduce the camber to even out the tyre wear  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #2 on: May 20, 2012, 08:34:20 pm »
I ran mine zero toe and camber, depends if you like a "French" rear end though  :grin:
Sideways yo!
Offline neil86
« Reply #3 on: May 20, 2012, 09:36:37 pm »
I don't mind changing toe will it stop the inner edge if run parallel. I would like to keep the camber though lol. Just it's that bad on my rear tyres you can actually see the odd wear it's not even across just the inner blocks some are raised some sit lower.
